engine runs on 2 cylinders, nothing on cylinder 2 and 4 |
JOE M |
Aug 27 2008, 08:46 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I know I am going to get beat up hard for this one but here goes. I have been trying to tune my carbs for a while now but have had no luck. I got the car to idle great ( I followed Rich`s advice by taking the linkage off and tuning each side individually. I got all 4 cylinders reading the same with the snail. I reved the engine a little and it started to pop through the cylinder #2. I let it idle for a while and pulled cylinder #2 wire and the engine continued to run the same. I pulled the wire for cylinder #4 and it still ran the same. I than pulled #1 and it almost stalled and the same was true for #3. I was puzzled that it would run so good on 2 cylinders. I turned the engine off and started it with cylinder #2 and # 4 off. It started up and idled fine. I verified the plugs were good by swapping them in the cylinders that were good and I swaped the wires as well. If my timing was way off could this cause this or is more an issue with the cap and rotor? I am so close but this is killing me because I cant tune it if it is not running on all 4 cylinders. Any ideas what is going on?
Aug 27 2008, 09:00 AM
Swap the carbs from one side to the other.
See if the issue follows the carbs...I bet it does. If so, take them both off and bring them to me. I will show you how to get them both running the same. Also, check your valve adjustments. Rich |
angerosa |
Aug 27 2008, 09:03 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
I think you can take your cap off and spin it 180 degrees? Switch the wires of course. Try to start it and if it's your cap cylanders 2 and 4 will work but not cylinders 1 and 3.
When did this start and what happened when it stopped working? |
angerosa |
Aug 27 2008, 09:11 AM
Swap the carbs from one side to the other. See if the issue follows the carbs...I bet it does. If so, take them both off and bring them to me. I will show you how to get them both running the same. Also, check your valve adjustments. Rich Good suggestion - You can also test this by verifying you have spark on these plugs and if so. Use a medicine dropper and drop some gas in the cylinders that dont work. Put everything back toegther. If the carb is the problem, they will fire a couple of times with gas in there and then stop after it's burned off. This method isn't as reliable troubleshooting as what Rich said but it might be easier than switching two carbs connected to a linkage. I've also sprayed wd-40 in the plug hole when I didn't have a dropper but don't tell anyone becasue I'm sure I'll get yelled at. |
JOE M |
Aug 27 2008, 09:29 AM
Swap the carbs from one side to the other. See if the issue follows the carbs...I bet it does. If so, take them both off and bring them to me. I will show you how to get them both running the same. Also, check your valve adjustments. Rich How far off would the valves have to be for this to happen? When I pull the wire from the distributor and hold it close I can see a spark but it appears to be weak.I think that I will swap the carbs later tonight and see what happens. It`s just wierd that it is 1 cylinder on each side. |
Aug 27 2008, 09:56 AM
You know what I did not look at is your firing order..
I was talking to much...happy to come by later today on my way to HD if you are around. I have done it, so dont think you cant do it...(IMG:style_emoticons/default/laugh.gif) Take a pic of the engine bay from the passenger side and post it. Let us see the firing order. Rich |
JOE M |
Aug 27 2008, 11:18 AM
You know what I did not look at is your firing order.. I was talking to much...happy to come by later today on my way to HD if you are around. I have done it, so dont think you cant do it...(IMG:style_emoticons/default/laugh.gif) Take a pic of the engine bay from the passenger side and post it. Let us see the firing order. Rich Rich I wont be home untill about 6:30 but thanks for the offer. I will try to get some pics but I think the firing order is correct. I will post pics later today or in the morning. |
ClayPerrine |
Aug 27 2008, 11:44 AM
Life's been good to me so far..... Group: Admin Posts: 15,447 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Common problem.
You swapped the #2 and #4 plug wires. If you reverse the rotation, it will look right. It won't backfire, but it won't run on those cylinders either....BTDT. Check the plug wires... on a type 4 with the distributor installed correctly, the two towers on the RH side of a 914 should go to the same cylinders on that side. The other 2 towers should have the plug wires crossed. Excuse the crude drawing.. but I think it gets the point across. |
JOE M |
Aug 27 2008, 05:43 PM
Here is a pic of my setup. Also I just got my H.E that I won on e-bay. Not ss but in decent shape. Last is my other hobby that is running my pockets dry. Dont know what costs more my saltwater tank or my 914lol.
Aug 27 2008, 05:47 PM
Take off the distributor cap, rotor and dust shield and take another pic please...It looks to be either way out of time or something funky. #1 should be up where #2 is on the cap... Rich |
JOE M |
Aug 27 2008, 05:59 PM
here is the pic.
Aug 27 2008, 09:09 PM
Im not sure which distributor that is, its either an 009 or an 050
If its 009 you have the correct distributor cap. If its an 050 you have the wrong cap. I can come over with my test meters to sort this out if you are around later this week. Its something simple but its easier for me to do it in person. I still suspect the carbs, but we can at least rule out the ignition pretty fast. If we spend an hour or so I am sure we can get it running right. I would have last time except the o-rings would have made it a waste of time... One more test. Take a flashlight. With the linkage disconnected on the carbs When you turn the key on...fuel pump running, car not running. Press down the carb throttle and look down each venturi to see if the accel pump is actually squirting fuel. It should do it when you press down the lever just once into each venturi. Check all four. Rich |
Aug 28 2008, 12:31 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The two front cylinder are dead? That brings to mind a really really bad possibility....
If the other checks don't turn up the problem, pull the lifters from one of those front cylinders. If you find one or both are chewed up, you have a flat cam. (IMG:style_emoticons/default/sad.gif) You might be able to tell just by looking at the movement of the rocker arms on one front cylinder compared to those on the rear cylinder. Not sure. I really really hope I'm wrong. --DD |
JOE M |
Aug 28 2008, 05:41 AM
Im not sure which distributor that is, its either an 009 or an 050 If its 009 you have the correct distributor cap. If its an 050 you have the wrong cap. I can come over with my test meters to sort this out if you are around later this week. Its something simple but its easier for me to do it in person. I still suspect the carbs, but we can at least rule out the ignition pretty fast. If we spend an hour or so I am sure we can get it running right. I would have last time except the o-rings would have made it a waste of time... One more test. Take a flashlight. With the linkage disconnected on the carbs When you turn the key on...fuel pump running, car not running. Press down the carb throttle and look down each venturi to see if the accel pump is actually squirting fuel. It should do it when you press down the lever just once into each venturi. Check all four. Rich Rich, All 4 cylinders are getting fuel. I did verify this. Damn I hope dave is not correct about 2 dead cylinders. I can tell you that I have new plugs and wires but I did not change the cap or rotor because they were not available at the time. Would I have to do a compression test to verify a dead cylinder? |
SGB |
Aug 28 2008, 07:11 AM
yes a compression test would be the easiest way to check that. My dizzy is 90 degrees out like that too. Drive gear put in wrong. Looks just like your orientation, and works fine.
JOE M |
Aug 28 2008, 07:36 AM
yes a compression test would be the easiest way to check that. My dizzy is 90 degrees out like that too. Drive gear put in wrong. Looks just like your orientation, and works fine. I know that I do not have great compression. However the 2 cylinders that are not working are at around 90psi. I have 1 cylinder that is at about 75~ 80 and I believe that is #1. #1 seems to run fine. I think the books say I should be around 120 or so but I cant remember. The other problem is that my valves are not adjusted yet so I am wondering how much of my compression loss could be a result of valve adjsutment? I am no mechanic but it seems that if the valves were not closing corectly than I would have low compression ( just a guess). If I place my hand over each barell I can feel a ton of suction. I am guessing again but if I had too low compression I probably would not be able to feel suction. I have never done a leak down test but I guess I will have to get my compression meter out and re-verify. Hope this does not mean I need some valve work because it looks like a big job. |
Aug 28 2008, 08:20 AM
If you want I can come over and we can test out the entire system.
Poorly adjusted valve are typically loose, not tight. Loose valve (loose rocker arms) will not open the valve all the way, but they will close them all the way. Unless you did the compression test with the engine warm, its not a valid set of numbers...everything needs to be hot. First thing I would do it pull each plug one at a time, ground out each plug while turning over the car and check that you have spark at each plug...this will prove you have a spark. Next thing I would do is manually set the motor to TDC using not only the fan TDC mark, but the Flywheel TDC mark to verify. Then I would ensure that the distributor is properly installed to reflect the TDC marks. I would also remove the rev limiting rotor and get a straight rotor...its just an odd variable I would not trust.. If you have never had the valve covers off, now is the time to get aquainted. I am still happy to come over and get it going, or if you want, bring it here I will get it going. Rich |
JOE M |
Aug 28 2008, 08:36 AM
If you want I can come over and we can test out the entire system. Poorly adjusted valve are typically loose, not tight. Loose valve (loose rocker arms) will not open the valve all the way, but they will close them all the way. Unless you did the compression test with the engine warm, its not a valid set of numbers...everything needs to be hot. First thing I would do it pull each plug one at a time, ground out each plug while turning over the car and check that you have spark at each plug...this will prove you have a spark. Next thing I would do is manually set the motor to TDC using not only the fan TDC mark, but the Flywheel TDC mark to verify. Then I would ensure that the distributor is properly installed to reflect the TDC marks. I would also remove the rev limiting rotor and get a straight rotor...its just an odd variable I would not trust.. If you have never had the valve covers off, now is the time to get aquainted. I am still happy to come over and get it going, or if you want, bring it here I will get it going. Rich I will try what you suggested. I do not think that my flywheel has a mark for TDC. I will also verify compression with the engine hot and repost. If there is no mark how can I verfiy TDC. I have had the valve covers off because when I got the car cylinder #1 had no compression at all. My brother in law looked at the valves and saw that it was not closing so he set the gap to .006". After that the compression went up but I know we checked it when it was cold not hot. So like I was saying what is the easiest way to verify TDC with no marks. I do remember seeing a thick post on the flywheel. But I also remember that when this post was at TDC the rotor was 180 off of cylinder #1 I think. I will check tonight when I get home. |
Aug 28 2008, 09:43 AM
There is a notch in the flywheel that can be view from underneath the motor. There is a viewing hole/ notch in the tranny bellhousing.
Quite possible that the push rods are not properly seated. When the distributor drive gear is not put in correctly, I suspect alot more than that. Rich |
JOE M |
Aug 28 2008, 10:29 AM
UH OH Rich,
What do you suspect is going on here. If you have time I could use some help when you are available. Thanks. |
Lo-Fi Version | Time is now: 11th May 2024 - 02:48 PM |
