valve adjustment ? |
yellow1 |
Aug 27 2008, 09:49 AM
Newbie Group: Members Posts: 48 Joined: 7-September 07 From: NY Member No.: 8,090 |
I bought my car last year, i have no mechanical skills i need to get my valves checked since i have no idea when was the last time it was done . The car was purchased from a used car dealer and he had no info on the car history .I found a vw place that is about an hour away from me That will do it .i have read on this and other forums that the car should sit over night, my ? is can i drive the car to the shop and let it sit for 3 hours and have the valves done ,would this be a okay or will i have problems .I was told it would be $125.00 to have them done is this about right for adjusting the valves.Thx
Aug 27 2008, 10:03 AM
$125 sound about right. Make sure they put in new valve cover gaskets.
3 hours....not enough. Drop it off the night before... Rich |
Joe Bob |
Aug 27 2008, 10:07 AM
Have them change the brake fluid as well, prolly was last done prior to the Clinton administration.... |
Cap'n Krusty |
Aug 27 2008, 11:16 AM
My shop rate, here in CA, is $110/hr. Adjusting the valves takes me 10-15 minutes, including putting the car on the lift and putting it back in the lot. Really bad ones take a half hour. For around $125-$130 you should be getting a small service, which includes an inspection, a valve adjustment, and an oil change and sump screen cleaning, and all the necessary parts.
The Cap'n |
Aug 27 2008, 11:33 AM
My shop rate, here in CA, is $110/hr. Adjusting the valves takes me 10-15 minutes, including putting the car on the lift and putting it back in the lot. Really bad ones take a half hour. For around $125-$130 you should be getting a small service, which includes an inspection, a valve adjustment, and an oil change and sump screen cleaning, and all the necessary parts. The Cap'n Question, On a lift, wheels hanging in the air. How do you lock one wheel so you can turn the motor? Or, how are you turning the motor?? Just curious. On jack stands I put two lug bolts in and hang a three foot pry bar between the bolts and touching the floor. I would like an even simpler way... Rich |
Joe Ricard |
Aug 27 2008, 11:39 AM
Why would you take the wheels off to set valves?
and it's like 30 minutes if I spend some time wiping off road grime or rubber dust. I imagine the Capt has one of them fancy remote switches he hooks to the starter. |
Aug 27 2008, 11:40 AM
Why would you take the wheels off to set valves? and it's like 30 minutes if I spend some time wiping off road grime or rubber dust. I imagine the Capt has one of them fancy remote switches he hooks to the starter. Easier access from the side without the damn tire in the way... I have dont it with the tire on...just easier IMHO with no tire. I always do something else when a car is up on jakc stands. (IMG:style_emoticons/default/laugh.gif) Rich |
rmital |
Aug 27 2008, 12:27 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
yellow1, where in NY are you?
adding your location might help if some other cluber is local to you. |
Cap'n Krusty |
Aug 27 2008, 04:07 PM
My shop rate, here in CA, is $110/hr. Adjusting the valves takes me 10-15 minutes, including putting the car on the lift and putting it back in the lot. Really bad ones take a half hour. For around $125-$130 you should be getting a small service, which includes an inspection, a valve adjustment, and an oil change and sump screen cleaning, and all the necessary parts. The Cap'n Question, On a lift, wheels hanging in the air. How do you lock one wheel so you can turn the motor? Or, how are you turning the motor?? Just curious. On jack stands I put two lug bolts in and hang a three foot pry bar between the bolts and touching the floor. I would like an even simpler way... Rich I follow the method clearly outlined in the classic threads, and I use a remote starter button, and I leave the spark plugs in and the tranny out of gear. The Cap'n |
yellow1 |
Aug 27 2008, 04:08 PM
yellow1 |
Aug 27 2008, 04:19 PM
$125 sound about right. Make sure they put in new valve cover gaskets. 3 hours....not enough. Drop it off the night before... Rich that,s what i thought , i guess i will have to find somebody to follow me there so i can drop it off , also get a ride back the next day to pick it up.Thx |
yellow1 |
Aug 27 2008, 05:44 PM
My shop rate, here in CA, is $110/hr. Adjusting the valves takes me 10-15 minutes, including putting the car on the lift and putting it back in the lot. Really bad ones take a half hour. For around $125-$130 you should be getting a small service, which includes an inspection, a valve adjustment, and an oil change and sump screen cleaning, and all the necessary parts. The Cap'n I wish u were here on the east coast cap'n, i would take my car to u in heart beat. I have read your method of doing the valves sounds easy ,but since i have never done them before i will pass for now, i was going to try it i went and purchased a feeler gauge and stands,then i chicken out i hope to 1 day learn to do it your way.Thx cap'n i enjoy reading your posts. |
yellow1 |
Aug 27 2008, 05:54 PM
(IMG:style_emoticons/default/agree.gif) Have them change the brake fluid as well, prolly was last done prior to the Clinton administration.... your right ,i will have to do that ,and u reminded me i will have them replace the fuel filter ,i got stuck for the first time this summer about 3 weeks ago because i ran out gas,the gas gauge got stuck about 1/4 tank,it seems like it is working now. |
Lo-Fi Version | Time is now: 11th May 2024 - 11:30 AM |
