QUOTE(Cap'n Krusty @ Aug 27 2008, 01:16 PM)
My shop rate, here in CA, is $110/hr. Adjusting the valves takes me 10-15 minutes, including putting the car on the lift and putting it back in the lot. Really bad ones take a half hour. For around $125-$130 you should be getting a small service, which includes an inspection, a valve adjustment, and an oil change and sump screen cleaning, and all the necessary parts.
The Cap'n
Question,
On a lift, wheels hanging in the air.
How do you lock one wheel so you can turn the motor?
Or, how are you turning the motor??
Just curious.
On jack stands I put two lug bolts in and hang a three foot pry bar between the bolts and touching the floor.
I would like an even simpler way...
Rich
