Wheel Spacers, rear tire rubbing? |
bob |
Aug 27 2008, 09:53 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
I ran a DE over the weekend and noticed the drivers side rear tire rubbed the paint off on the inner fender... what size spacer is anyone using? (if any?)
thanx! -bob |
GaroldShaffer |
Aug 27 2008, 10:06 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
what size tire are you running? What kind of rim also? I was runnig a set of keizer rims with 205 50 15 kuhmo's and a 1/4" wheel spacer in back to clear the brake calipers. Only problem was even with the my fender lips rolled it still would rub on hard corners. Over time it did heat the fender enough that the paint discolored at the rub point.
I switched back to minilite rims with teh same tire, no spacer and have had no problems. |
bob |
Aug 27 2008, 10:08 AM
205's on regular steel rims. (5.5 wide)
GaroldShaffer |
Aug 27 2008, 10:31 AM
what is you toe & camber setup? also are you running stock springs?
mskala |
Aug 27 2008, 11:21 AM
each tire brand is different width;
each rim type is different backspace; each 914 is slightly different; stiffer springs/shocks will limit movement more; etc. I have experienced rub same as you and I have at least 1/4" static gap. If it's just a minor rub, just try to find or make a 1/8" spacer. If you want to be serious, unbolt the shock and move the tire through the whole useful range of motion while checking for decent static gap. |
bob |
Aug 27 2008, 11:22 AM
everything is stock (stock 914-6)
bob |
Aug 27 2008, 11:52 AM
thanx ... I figured I'd just add a 1/4" spacer, but was wondering what everyone else does when their car rubs.
BTW- Mark, I haven't been following any NCR. NER events since I moved, but how have you been doing in AX? still beating charles? -bob |
jdogg |
Aug 27 2008, 02:30 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
There used to be guy on Ebay that custom made hubcentric spacers for 4 lug cars, but I can't find him any more. Does anyone else know of a source for 1" or so 4 lug hubcentric spacers???
Bob- Where did you run your DE at? |
bob |
Aug 27 2008, 03:52 PM
Summit Point...
-bob |
Racing916 |
Aug 27 2008, 07:31 PM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
Hey Bob,
Just put some bike tires on that thing and you will be set!! |
mskala |
Aug 27 2008, 09:56 PM
BTW- Mark, I haven't been following any NCR. NER events since I moved, but how have you been doing in AX? still beating charles? -bob Hi Bob, I couldn't place you from your screen name there for a bit. Charles was beating me for a couple years, but not this year. Only problem is a 997 GT3RS and a more than slightly modified early 911. I'm not mathematically out of the trophies yet. |
Demick |
Aug 28 2008, 09:33 AM
You may also want ot check your trailing arm bushings. Mine were shot, and the way I noticed is that the rear tires began rubbing on the inner fender during autox.
6freak |
Aug 28 2008, 09:45 AM
thanx ... I figured I'd just add a 1/4" spacer, but was wondering what everyone else does when their car rubs. BTW- Mark, I haven't been following any NCR. NER events since I moved, but how have you been doing in AX? still beating charles? -bob 1/4 spacers will require longer lug studs.I tryed it because of the same issue your haveing..I was running 205/50/15 Kumho 710 on cookie cutters.good luck |
Chris Pincetich |
Aug 28 2008, 04:18 PM
Garold - I am using your old rims and love them (IMG:style_emoticons/default/beerchug.gif)
They did rub inside before using the spacer (1/4 or 5mm I think). I THOUGHT I rolled the fenders enough but during my races they did rub and caused the fender to heat up at the one spot and a small paint bubble formed. I rolled the lips again when they were hot and it has not happened again. I found an eBay seller for 4 lug spacers, search VW Bug parts on EBay stores. A 914 - 6 probably uses 5 lug, which are true Porsche parts and more expensive (IMG:style_emoticons/default/dry.gif) |
Joe Bob |
Aug 29 2008, 11:34 AM
You may also want ot check your trailing arm bushings. Mine were shot, and the way I noticed is that the rear tires began rubbing on the inner fender during autox. (IMG:style_emoticons/default/agree.gif) Or the suspension ear....the passenger side isn't the only one that can fail. |
bob |
Aug 29 2008, 12:04 PM
suspension ear is good! I'm pretty sure the bushings are ok. (for a 38 YO car!) but I'll take a look at 'em . I found some 1/8" spacers and I'll try that for now...
thanx! -bob |
Racer |
Aug 29 2008, 03:07 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Before you throw on some spacers, take a look at the car while its sitting on the ground. Crawl underneath and see how much room (if any) is between the tire and the fenderwell.
In theory, if there is room now, there would be room on the track. A tire doesn't flex at the top afterall, but at the bottom when its under cornering loads. If there is room now, I would be more suspect of failing bushings/ears/arms that are flexing under the grip of the tire and causing you to rub. A spacer may solve the problem of rubbing, but doesn't mean your 38YO bushings are doing there job! |
mskala |
Aug 29 2008, 05:18 PM
QUOTE In theory, if there is room now, there would be room on the track. A tire doesn't flex at the top afterall, but at the bottom when its under cornering loads. Sorry, this is not true. Not only does the tire deflect all the way around (though less farthest from the ground), the place on the 914 inner fender that sticks out the most is only about 2/3 of the way up. Shorter and stiffer sidewalls and the proper rim width will reduce the amount of the flex. |
Lo-Fi Version | Time is now: 1st May 2024 - 04:29 AM |
