Engine Gasket Set, 1.7 vs 2.0 whats the difference? |
stephenaki |
Sep 5 2008, 01:14 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, components are at Boxter Motors to be balanced and I am getting ready to do the re-assembly. I need to order the engine gasket set but not sure which one to order.
To refresh everyone's memory, I am converting the 1.7 to a stock 2.0L. The case is the 1.7 but the pistons and cylinders, crankshaft and connecting rods are all 2.0. The engine will be carbureated. AA has a kit that states 1.7 and 2.0, PP has 3 seperate kits, 1.7, 1.8 and 2.0. Is there a difference between the sets? Since everything I read says that that the only differences between 1.7 and 2.0 are mostly internal and the FI system I should be able to order a 2.0 kit correct? Could use some insight here. (IMG:style_emoticons/default/confused24.gif) |
914Sixer |
Sep 5 2008, 07:49 AM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The difference is in what heads and exhaust you are using. Are you using 2.0 heads? The 1.7,1.8 are 4 bolt intake, 2.0 is 3. The other item that is different will be the heat exchanger gaskets to the muffler. The rest should be the same.
DNHunt |
Sep 5 2008, 08:23 AM
Also remember that the front and main oil seals are not included in the gasket kit. Also the cam plug is not included.
dave |
Jake Raby |
Sep 5 2008, 09:04 AM
The cylinder heads that you are using will cictate the gasket set you need, all the other gaskets are the same.
if you are using 3 stud Porsche 2.0 heads use the 039 part numbered kit, if using 2.0 Bus heads you'll need the Bus gasket set. |
stephenaki |
Sep 5 2008, 01:28 PM
The cylinder heads that you are using will cictate the gasket set you need, all the other gaskets are the same. if you are using 3 stud Porsche 2.0 heads use the 039 part numbered kit, if using 2.0 Bus heads you'll need the Bus gasket set. Thanks, the heads are 1.7 machined out for the larger cylinders and pistons; this being said I will order the 1.7 gasket set and the seals. |
Lo-Fi Version | Time is now: 11th May 2024 - 11:43 AM |
