OK, components are at Boxter Motors to be balanced and I am getting ready to do the re-assembly. I need to order the engine gasket set but not sure which one to order.
To refresh everyone's memory, I am converting the 1.7 to a stock 2.0L. The case is the 1.7 but the pistons and cylinders, crankshaft and connecting rods are all 2.0. The engine will be carbureated.
AA has a kit that states 1.7 and 2.0, PP has 3 seperate kits, 1.7, 1.8 and 2.0. Is there a difference between the sets? Since everything I read says that that the only differences between 1.7 and 2.0 are mostly internal and the FI system I should be able to order a 2.0 kit correct? Could use some insight here.
