Hi to everyone and a question |
kkid |
Sep 5 2008, 04:24 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hi everyone,
I am a new owner of the 914 and have been learning a lot from this site. My '74 2.0 died 3 times on the road since my owner ship(last December) but this community site makes me possible to keep the car running. (IMG:style_emoticons/default/driving-girl.gif) I never feel like giving up. This is amazing! (IMG:style_emoticons/default/cheer.gif) By the way, as for the 914 tranny, I remember some one says synthetic fluid is not good. How about synthetic blend fluid? Is synthetic blend OK as long as it is GL5 rated? It is time for my 914 to change the speedo angle drive so I will change the fluid at the same time. Mahalo in advance! (IMG:style_emoticons/default/smile.gif) |
SirAndy |
Sep 5 2008, 04:27 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have used "Swepco 201" with very good results for a few years now. Where in Oakland are you? (IMG:style_emoticons/default/idea.gif) Andy |
SGB |
Sep 5 2008, 04:31 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Mobil 1 gear lube is too slippery. The synchros don't spool up as well as with Swepco. Changing the speedo gear doesn't open the tranny case though, so you will need to pull the plugs on the side. Glad the site helps. The internet is like 9 lives for old cars. (IMG:style_emoticons/default/smile.gif)
kkid |
Sep 5 2008, 04:42 PM
Thanks for the greeting, Andy!
As everyone else I would like to use Swepco but it is too costly for me so I ran to local parts shop and got 3 qt of Valvoline made synthetic blend. Do you think there is no problems using this???? By the way , I'm in Redwood Heights of Oakland. (IMG:style_emoticons/default/bye1.gif) |
kkid |
Sep 5 2008, 05:15 PM
Thanks for the input, Scott. (IMG:style_emoticons/default/pray.gif)
It took me more than a week to get the drain and fill plugs loosened. I still see slight fluid leak from the angle drive it self after having O-ring and seal ring changed. And I have no idea when was the last time the fluid was changed. That is why I am saying it is great time to change the angle drive and the fluid at the same time. Do you know if the Valvoline synthetic blend tranny fluid works as well? By the way, is this what they call "the dead whale smell"? |
lotus_65 |
Sep 5 2008, 08:11 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i personally never had trouble with swepco. also, i don't think per ounce and given the life of the oil, that it's too expensive. |
r_towle |
Sep 5 2008, 08:15 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Thanks for the input, Scott. (IMG:style_emoticons/default/pray.gif) It took me more than a week to get the drain and fill plugs loosened. I still see slight fluid leak from the angle drive it self after having O-ring and seal ring changed. And I have no idea when was the last time the fluid was changed. That is why I am saying it is great time to change the angle drive and the fluid at the same time. Do you know if the Valvoline synthetic blend tranny fluid works as well? By the way, is this what they call "the dead whale smell"? Never use synthetic gear oil in a 914 transmission. Synthetic gear oil wears out the brake bands very quickly. Use regular GL5 gear oil, no blends, no additives. THAT is what the transmission is designed to use. If you use synthetic you will not have a functioning transmission in a short amount of time. Rich |
Lo-Fi Version | Time is now: 20th May 2024 - 09:54 AM |
