Need sway bar measurement, U-tab to balljoint |
Cevan |
Sep 6 2008, 07:36 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I'm looking for the measurement from the center of the balljoint to the center of the U-tab for an OEM front sway bar. PP's site uses 5 1/8 inch. Thanks.
Edit - I just measured my '74 parts car which has a u-tab welded to the control arm but no swaybar has ever been installed on the car. It's aprox 4 inches center to center. |
roadster fan |
Sep 6 2008, 01:15 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I just measured the a-arm from my 73, and it is hard to get an accurate reading because I have the ball joint out of the arm and could not locate it quickly. It appears to be a little more that 4" center to center.
I measured from the outboard edge of the a-arm to the center of the U-tab and that appears to be 5 1/8". I can take a pic if you need one. Jim |
Sep 6 2008, 02:38 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would urge you to be accurate, but only on ensuring that both side match. If you are using a system that the drop links use heim joints on the end, you have a few MM of play in your placement.
Even the heim joints will bind if the U-tab is mounted to close to the ball joint...they are already at an angle when used in the stock position. Rich |
Jeff Hail |
Sep 6 2008, 03:26 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Hope this helps
Cevan |
Sep 6 2008, 04:45 PM
Thanks for the replies. When my car was at Tangerine Racing, they noticed that the u-tab looked a little too far inboard. It looks like a PO had the drop link reversed (bent inboard) when the u-tab was positioned. I flipped it around and the u-tab lined up with the above measurements. It turned out to be almost 2 inches off. (IMG:style_emoticons/default/blink.gif) Figure my anti-sway bar hasn't been too effective up 'til now.
Lo-Fi Version | Time is now: 27th May 2024 - 08:58 PM |
