Oil cooler removal |
Curvie Roadlover |
Mar 26 2003, 12:04 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
OK, I'm attempting to replace my oil cooler seals on my '76 2.0 in an attempt to fix my oil leak problem. The engine is out of the car, the tin is off, except the piece directly over the cooler. This piece goes all the way from the top of the oil cooler to below the pushrod tubes. I'm told this piece of tin has to go on the engine before the cylinders go on, so I'm assuming I can deal with the cooler with this piece still on the engine. I've removed the 2 13mm bolts that hold the coolers' outboard bracket to the fan shroud. I've also removed the 2 10 mm nuts on the forward side of the cooler. It isn't even loose at this point. What else do I have to do to get the oil cooler off? (IMG:style_emoticons/default/blink.gif)
Thanks in advance, Perplexed in Michigan |
Bleyseng |
Mar 26 2003, 12:25 PM
There are 3 small 10mm nuts that hold the oil cooler onto the bracket. Remove those and it comes off. The tin should come off too, I don't remember any tin not being able to be pulled off because of the P&C's.
Geoff |
TonyAKAVW |
Mar 26 2003, 01:41 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Having just done this myself a few weeks ago, I cannot remember a piece of engine tin that had to stay on... My engine is a 75 1.8, so maybe there is a slight diffrence but I doubt it. I took off the fan and shroud and alternator and all of that before I took the cooler out. NOt sure if you've done that yet... And yes, there are three small nuts that you have to take off and the cooler slides forward along the three studs to which these bolts attach.
One reccomendation I have is to get your cooler pressure tested. I did the seal replacement and found that it didn't help. Turns out the cooler has a leak. The manual says test to 85 lbs. -Tony |
Mar 26 2003, 05:22 PM
Slide the piece of tin that's on top of the cooler upward. It should come out. The cooling flaps have to be removed for this. I don't think the fan shroud has to be off, but you want it off anyway...
The cooler has three M6 (10mm wrench size) mounting nuts, and a clamp around the outer end that bolts to the fan shroud. --DD |
Curvie Roadlover |
Mar 26 2003, 09:39 PM
Thank you, gentlemen, for your timely responses. I was hoping to be able to get at the oil cooler without taking the fan and shroud off, but if that's the way it must be, then at least now I know. I'll test the cooler before re-installing too.
The weather's getting nice here in SE MI. I'm anxious to get the engine back in the car and start (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:48 PM |
