A new 914 on 9-14 !, Running and driving daily now! |
Root_Werks |
Sep 18 2008, 02:15 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Picked this one up from Jeff on the site. Color changed car, cool color though. I think it's a factory color? I had a 1968 911L that I swear was exactly the same color as this.
1974 2.0 with really little dual carbs. Attached image(s) |
Tom |
Oct 20 2008, 10:52 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Nice work Dan. Hope to see that car next year over at the AX's.
Tom |
PeeGreen 914 |
Oct 21 2008, 01:23 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Nice work Dan. Hope to see that car next year over at the AX's. Tom (IMG:style_emoticons/default/agree.gif) You and your wife need to make it out. It would be great to see you guys. |
pete-stevers |
Oct 21 2008, 03:52 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
lookin mighty fine danny boy!!!!
when your ready...i am rolling harlot to your shop for some flares |
Root_Werks |
Oct 21 2008, 09:01 PM
lookin mighty fine danny boy!!!! when your ready...i am rolling harlot to your shop for some flares Give me a little more time and yeah, we'll (IMG:style_emoticons/default/welder.gif) get your 914 done! |
Root_Werks |
Oct 26 2008, 11:28 PM
There is a lot that was done this weekend. Brakes are all working (car sat for 10 years), engine/trans hung. I wound up picking up a FI setup from Rich locally so I am setting the 914 back up for that. Front/rear valances on.
Root_Werks |
Oct 26 2008, 11:30 PM
I welded up holes in the bumpers today and am prepping those for paint. Should have bumpers back on in a few days.
Had to free up ALL e-brake stuff. Ugh, sitting for a decade doesn't help. Works perfect now. Attached image(s) |
JRust |
Oct 27 2008, 03:40 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Looking good Dan! A couple more weekends & you'll be on the road. Be nice to drive a teener again heh? Keep up the good work & thanks again for your help this weekend (IMG:style_emoticons/default/biggrin.gif)
Root_Werks |
Oct 31 2008, 10:12 AM
Worked on it pretty late last night and got everything all hooked up. Tossed in a battery and the fuel pump actually primed like it should. (IMG:style_emoticons/default/w00t.gif) I worked the key and let it prime a few times, no leaks, another yeah since the first couple of FI pumps did leak. Thanks to Rich D. for letting me come over and snag the one off his parts car, guess we should have just grabbed that one with the original FI stuff anyway.
Battery wound up being way too dead to turn over the engine. I have it at work with me on a charger. So no more carbs, FI off of Rich's 76' 2.0 parts car. I did buy a new CHT and fuel pressure regulator. Hopefully things like the injectors are still good. I'll wait until after I get the car fired off, but I'll replace all other sensors, the TPS and injector points. Another $300 in parts, but it'll be worth it. I am hoping to keep just above that 30mpg mark. Oh yeah, off with the rivs and on with the Mahles! Picked up a set of 5 from Rich's parts car as well. Starting to get excited about driving a teener again! (IMG:style_emoticons/default/driving.gif) Maybe this weekend? (IMG:style_emoticons/default/boldblue.gif) |
Oct 31 2008, 10:25 AM
Worked on it pretty late last night and got everything all hooked up. Tossed in a battery and the fuel pump actually primed like it should. (IMG:style_emoticons/default/w00t.gif) I worked the key and let it prime a few times, no leaks, another yeah since the first couple of FI pumps did leak. Thanks to Rich D. for letting me come over and snag the one off his parts car, guess we should have just grabbed that one with the original FI stuff anyway. Battery wound up being way too dead to turn over the engine. I have it at work with me on a charger. So no more carbs, FI off of Rich's 76' 2.0 parts car. I did buy a new CHT and fuel pressure regulator. Hopefully things like the injectors are still good. I'll wait until after I get the car fired off, but I'll replace all other sensors, the TPS and injector points. Another $300 in parts, but it'll be worth it. I am hoping to keep just above that 30mpg mark. Oh yeah, off with the rivs and on with the Mahles! Picked up a set of 5 from Rich's parts car as well. Starting to get excited about driving a teener again! (IMG:style_emoticons/default/driving.gif) Maybe this weekend? (IMG:style_emoticons/default/boldblue.gif) What did you do with the carbs, what size are they, and would you sell them? JOEM here needs a set of carbs...he has an old set of webers that I think are past rebuilding...seems to be a few casting issues and reamed out threads that make it damn near impossible to make them work.... He would like a smaller set anyways. Rich |
Root_Werks |
Oct 31 2008, 11:32 AM
They are Solex P11-4's and in VERY good shape. They were taken appart and cleaned by an aircraft mechanic but not completely re-assembled. I got most of both back together-preset one of the floats etc. Shafts are tight, NO wear on the throats where the butterflies touch at all. Jetted for a 100hp 912 motor.
I have Brand new K&N's, linkage and manifolds for 2.0 or 1.7-1.8 Type 4. PM me if interested. Need a little finishing up which I could do if you like. I also have a good parts list/diagram. 40mm with 32 vents, 1.1's and .07's I believe? Should be just about right for a 2.0 engine. 1.8 or 1.7 might be a little much. Attached image(s) |
Root_Werks |
Nov 3 2008, 10:34 AM
Sorry guys, no new pics, I promise soon.
Car runs perfect. Putting the FI back on was a real PITA! Thanks to Rich D. for selling me the FI from his parts car and then bugging him for fuel pumps until we found one that didn't leak. Also thanks to Jeff H. for letting me borrow his MPS. Geoff is making one for me so you'll have yours back soon. Put in a new tinted rear window yesterday, painted the bumpers, did more de-rusting etc. The car is pretty much ready to go except for an air cleaner top. It'll be nice to drive a 914 again. (IMG:style_emoticons/default/driving.gif) It sounds really good, fires right up. Oh yeah, put on my CAMP driving lights I have had sitting around for like 3 years. (IMG:style_emoticons/default/rolleyes.gif) |
sixnotfour |
Nov 3 2008, 12:18 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
good news ,
I am going to storage for keys and air cleaner today . |
Root_Werks |
Nov 3 2008, 12:38 PM
good news , I am going to storage for keys and air cleaner today . (IMG:style_emoticons/default/laugh.gif) Dude, I cannot tell you how frustrated I was getting with the "Key that sort of works" getting the car started over the weekend. I was being so careful not to bend or break the key off. A delicate balance of wiggling, pulling out just a little,,,not too much etc. Thanks Jeff, I appreciate it. |
Root_Werks |
Nov 3 2008, 10:33 PM
Pics! The running engine in and waiting to drive.
Root_Werks |
Nov 3 2008, 10:35 PM
Those cool CAMP914 driving lights. Notice the touch up under the front bumper area. Cleaned up anything that even hinted it could ever BE rust and slathered it. Heck, I'm so close, the rear wheels are on!
Root_Werks |
Nov 3 2008, 10:37 PM
Bumpers painted, still a little fresh.
Root_Werks |
Nov 3 2008, 10:38 PM
Cool driving light grills painted as well.
PeeGreen 914 |
Nov 4 2008, 12:58 AM
Looking good Dan. I can't wait to see it on the road. (IMG:style_emoticons/default/piratenanner.gif)
Root_Werks |
Nov 11 2008, 09:16 PM
Pretty much done with the 914 now. I went to put the engine lid back on and forgot about the rear latch thingie that was broken. PO used screws, it worked, but I went for welding it back on.
Root_Werks |
Nov 11 2008, 09:18 PM
All bumpers and valances back on. Spent time today putting interior back in.
Lo-Fi Version | Time is now: 19th May 2024 - 12:32 AM |
