Left rear scraping sound, what the heck is it? |
blitZ |
Sep 22 2008, 07:29 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I just replace my rear calipers and pads. Set the vent correctly and gave it a good bleeding. On my test run around the neighborhood, I noticed a faint scraping sound which gets faster the faster I drive. However, it doesn't disappear when I apply the brakes. Any ideas?
URY914 |
Sep 22 2008, 07:33 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,811 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Remove the neighbor's cat from under the car.
Make sure your disc is "true" not warped. |
blitZ |
Sep 22 2008, 07:48 PM
Remove the neighbor's cat from under the car. Make sure your disc is "true" not warped. I actually had new rotors to install, but the old ones were not bad. I had removed one of the screws on that side. The other screw stripped and the main nut wouldn't budge. So my lazy self said to heck with it. Could removing one screw cause the rotor to warp? |
URY914 |
Sep 22 2008, 08:07 PM
Remove the neighbor's cat from under the car. Make sure your disc is "true" not warped. I actually had new rotors to install, but the old ones were not bad. I had removed one of the screws on that side. The other screw stripped and the main nut wouldn't budge. So my lazy self said to heck with it. Could removing one screw cause the rotor to warp? Did you have the old ones mic'd and turned? |
SGB |
Sep 22 2008, 08:25 PM
Could it just be the dust shield?
Dr Evil |
Sep 22 2008, 09:52 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Not all the rotors are the same diameter. You may wish to check the diameters of the new vs the old.
dlestep |
Sep 22 2008, 10:08 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
After you investigate all those other things, check your vent clearance....
brer |
Sep 23 2008, 12:26 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
did you look in the trunk?
blitZ |
Sep 23 2008, 05:05 PM
Well, call me an idiot...
breif pause. I had replaced the brake line hoses and the metal line between the hose and caliper was repositioned and rubbing on the wheel. Easy fix, thought I had really borked something. Fortunately, Freddy Krueger was not in my trunk. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 02:19 AM |
