throttle cable issues, the threaded end (at the engine) keeps breaking |
mattp |
Sep 28 2008, 06:47 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I just got a new throttle cable and while tightening the nut on the threaded end (at engine) the threded part broke, it left me enough so I could do it again and it broke again?
I am talking about the end that is at the engine, its threaded and the cable runs through it. Any ideas? I got it from Pelican and am asking for an exchange. Matt |
ChrisFoley |
Sep 28 2008, 06:56 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I never heard of that end failing. It should have a nut on both sides to hold it securely to the bracket and be somewhat adjustable. The nuts only need to be tight enough to keep the sheath from moving about. A lock washer on one side is sufficient to prevent loosening.
Under these conditions, if the threaded end of the cable breaks, it is certainly defective. BTW, IIRC you had a rear main seal leakage problem. What happened with that? |
Zundfolge |
Sep 28 2008, 07:06 PM
Senior Member Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains |
I just installed a new throttle cable today and had the same thing happen. The nut that holds the casing of the throttle cable in place is just too damn easy to over tighten and shear off. I had to use a dremel to cut off the broken piece and then drilled out the one off the old cable so it would slide over the metal piece that hooks to the carb linkage.
The cable I replaced is one I bought from Pelican 3 months ago (which broke at the pedal end) I've come to the conclusion that the cables they're selling are crap. The new cable feels like it takes about 1/3rd the pressure on the pedal so there was clearly something wrong with the old one. Whenever I have to replace this cable again I'm going to try to find another vendor ... or I'll spring for the expensive "Terry Cable" they also sell ... maybe its better made. |
PeeGreen 914 |
Sep 28 2008, 09:37 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
You don't need to buy another type of cable. The other would have been fine if you just didn't over tighten. It is easy to do for those who just are too strong for their own good. (IMG:style_emoticons/default/biggrin.gif)
sean_v8_914 |
Sep 29 2008, 12:12 AM
I have seen some of the newer cables to be thin in this area. teh Terry brand does not exibit this flaw
blitZ |
Sep 29 2008, 09:09 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Whenever I have to replace this cable again I'm going to try to find another vendor ... or I'll spring for the expensive "Terry Cable" they also sell ... maybe its better made. I bought a cheap cable and had the thread breaking problem. I replaced it with a Terry Cable, much more solid. |
mattp |
Sep 29 2008, 10:22 AM
I would have thought it was a case of not knowing my own strength but it wasnt even halfway when it broke! then it broke again!!
it also seemd to be slightly thinner than the old cable's end. As for my oil leak, yes I found it, it was one of the galley plugs, it was tight enough that when the engine was not running it showed no sign of being loose or of leakage but as pressure built up it would leak, what a PITA that was. I was watching a show yesterday where two mechanics built an engine in under 12 minutes (yes it ran) I cammented to my wife that at the rate I amgoing its going to be close to a year!! next step, reorder throttle cable, install, then balance carbs |
Lo-Fi Version | Time is now: 17th May 2024 - 12:47 PM |
