Dr Evil...problem with shift rod on 73 tranny |
dlestep |
Sep 29 2008, 10:53 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Dr. Evil,
I have a 73 tranny in the 74 that has two problems. The socket head cone screw is stripped (most likely the previous nut ball used a SAE instead of a metric allen). I would like to remove it and maybe replace it with the next size up. Not sure how to do this without damaging it. Also, the pin (where the coupler bushings go) on the other end is rusted and has become "one with the rod." I was thinking of soaking it in blaster and try to press it out. It looks like its going to break. May have to drill it out. Do you know the correct diameter of the pin? (IMG:style_emoticons/default/unsure.gif) Even better do you know where I can get a replacement? any and all help is appreciated, tks Dave (IMG:style_emoticons/default/type.gif) |
Eric_Shea |
Sep 30 2008, 08:56 PM
Sorry Dave... he's too busy (IMG:style_emoticons/default/jerkit.gif) playing his new guitar to reply.
My fault. (IMG:style_emoticons/default/headbang.gif) |
Dr Evil |
Sep 30 2008, 09:31 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/tongue.gif) Eric.
Dave, You may have to drill out the cone screw carefully if soaking it doesnt work. It would likely be easier to just break the coupler off as used ones are pretty readily available. I probably even have on. As for the pin on the end, those can be a real bitch to press out. Heat is your friend, but not while in the car. Let me see if I have the part for you this weekend. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:29 AM |
