Dr. Evil,
I have a 73 tranny in the 74 that has two problems.
The socket head cone screw is stripped (most likely the previous nut ball used a SAE instead of a metric allen). I would like to remove it and maybe replace it with the next size up. Not sure how to do this without damaging it.
Also, the pin (where the coupler bushings go) on the other end is rusted and has become "one with the rod." I was thinking of soaking it in blaster and try to press it out. It looks like its going to break. May have to drill it out. Do you know the correct diameter of the pin?
Even better do you know where I can get a replacement?
any and all help is appreciated,
tks
Dave
