Will they fit? Koni strut inserts into a 911 boge, 82r 1730 504 |
computers4kids |
Sep 30 2008, 01:11 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Larry, has a set of Koni 82r 1730 504 struts for sale and we are trying to deterimine if they will fit inside my Boge 911 3" spacing housings.
I found those numbers on a early thread and they said they would fit a 914 boge. Here are Larry's measurements: Ok the part #'s 82R 1730 504 Housing length only the specific housing is 12.6875 " ~ From bottom of housing to bottom of screw top ~13.5" 45.5 mm very accurate measured with digital caliper There is also a nub on the bottom of the strut housing that is ~24.8 mm. I measured my stock Boge inserts and they measure 17.5 inches tip to tip (bolt tip). That appears to be 5" difference...does that sound right. Sorry for the dumb question, but the more I've read, the more confused I am. Attached image(s) |
sixnotfour |
Sep 30 2008, 01:34 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE 82r 1730 914-914-6 fitment , therefore will work in the 911 boge |
TeenerTim |
Sep 30 2008, 08:51 AM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
I don't know about the exact numbers but I ordered Koni reds for a 914 (all) and they fit perfectly in the 911 struts that you are using.
East coaster |
Oct 1 2008, 08:17 PM
Senior Member Group: Members Posts: 1,672 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Lo-Fi Version | Time is now: 16th May 2024 - 06:56 PM |
