Larry, has a set of Koni 82r 1730 504 struts for sale and we are trying to deterimine if they will fit inside my Boge 911 3" spacing housings.
I found those numbers on a early thread and they said they would fit a 914 boge.
Here are Larry's measurements:
Ok the part #'s 82R 1730 504
Housing length only the specific housing is 12.6875 " ~
From bottom of housing to bottom of screw top ~13.5"
45.5 mm very accurate measured with digital caliper
There is also a nub on the bottom of the strut housing that is ~24.8 mm.
I measured my stock Boge inserts and they measure 17.5 inches tip to tip (bolt tip). That appears to be 5" difference...does that sound right.
Sorry for the dumb question, but the more I've read, the more confused I am.
