Do i need the heater blower? |
turnaround89 |
Sep 30 2008, 11:09 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I am trying to get as much off my car as possible and i don't plan on using the car in the cold, let alone drive in the cold, so can i pull the heater blower in the engine compartment without any worries?
SirAndy |
Sep 30 2008, 12:11 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am trying to get as much off my car as possible and i don't plan on using the car in the cold, let alone drive in the cold, so can i pull the heater blower in the engine compartment without any worries? Yes, you can. Make *sure* you cap off the wires correctly so they don't shorten out. The blower runs off the same fuse as the fuel pump ... Probably a good idea to pull the blower relay off the relay board. It's relay #55, the one closest to the rear of the car. Do you still have the J-tubes and stock HE's? if so, you can pull the J-Tubes and heater flapper valves as well. Just block off the heater tube opening at the longs so you don't get any exhaust fumes inside the car. (IMG:style_emoticons/default/bye1.gif) Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 09:09 AM |
