> 914World Classifieds Rules
10 Pages V « < 3 4 5 6 7 > »
> FS: $9.14 & more, * items added *
Tomhilmes
post Feb 9 2012, 08:25 PM
Post #81
I'm new here ...
Rich,
Thanks again for the help. The fresh air box and tubes was perfect. Packaging for shipment was excellent.
I also appreciate the tip on repairing the seat belt retractors. Decided to stick with my visors. I wish they were filled out a little better but the flat is still there.
Wishing I had a known good set of stock or close to stock rear spring/strut assemblies. I've got a lean.
Thanks again,
Tom Hilmes
Tomhilmes
post Feb 9 2012, 08:26 PM
Post #82
I'm new here ...
Rich,
Thanks again,
Tom Hilmes
Ed_F
post Feb 12 2012, 04:27 PM
Post #83
Rich, your PM box is full. I'm interested in the front Valance.
bryanf
post Feb 13 2012, 11:30 AM
Post #84
Rich,
I got the calipers and installed them this weekend. I can't believe how fast they came! I was going to have them rebuilt before installing, but they looked so clean I thought I'd give them a try and they work perfectly.
Thanks!
Bryan
914werke
post Feb 13 2012, 03:29 PM
Post #85
Sorry folks Ive been haveing some...Technical difficulties (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/wub.gif)
Promise to try to catch up with any unanswered PM's or posts. (IMG:style_emoticons/default/bye1.gif)
914work
post Feb 18 2012, 08:53 PM
Post #86
PM sent (IMG:style_emoticons/default/icon_bump.gif)
flash914
post Feb 19 2012, 12:45 AM
Post #87
Do you still have the block/ tool for adjusting transmission forks Can't find the number for it PM me if you do. Gordon
rph20355
post Feb 20 2012, 11:27 PM
Post #88
I'm interested in one of the .5 shafts (#130). Approximate shipping cost to 48094 when you get a chance? Thanks.
Ron
sbruzek
post Feb 25 2012, 07:31 PM
Post #89
I'll buy the relay board. Do you have a rear drivers side latch for the targa top, The one behind the driver head. Thanx
914werke
post Feb 28 2012, 02:37 PM
Post #90
rgolia
post Feb 28 2012, 05:56 PM
Post #91
GeoJoe
Do you still have the dash mount washer switch?
914werke
post Mar 1 2012, 12:24 PM
Post #92
To the TOP!
markyb
post Mar 9 2012, 08:54 AM
Post #93
PM sent regarding the rain tray drain tubes....
Bob L.
post Mar 13 2012, 09:39 AM
Post #94
P.M. sent re: FI kit
jcambo7
post Mar 13 2012, 11:44 AM
Post #95
#88 Carb Fuel Pump (Faucet style)$20.00
Could you send me a picture of this Rich. jrcampbell7@hotmail.com
914werke
post Mar 21 2012, 11:36 AM
Post #96
timothy_nd28
post Mar 21 2012, 03:46 PM
Post #97
PM sent regarding those fine looking seat belt latches, if still available.
MassTeener
post Mar 21 2012, 09:06 PM
Post #98
QUOTE(daniel951 @ Jan 21 2012, 03:31 PM) *
QUOTE(rdauenhauer @ Oct 2 2008, 03:48 PM) *
For sale misc. items. (Pics start in 2nd post & may or may not be actual)
If you don’t see some thing you’re after, ask there's a good chance I have it.
If you want something and feel the need to dicker, make offer. Trades welcome.
I’m liquidating all the stuff horded for my restoration, but left over,
so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted.
All prices quoted less actual shipping/handling.
(International sales via Fedex 100% shipping & item prepay only!)
Because the majority of these items are for small $’s, Check, MO or buyer covers the PayPal fees
(better yet check into POPMoney (IMG:style_emoticons/default/smile.gif) ).
Shipping can be combined on multiple items but in doing so *please* be patient,
it can take some time to adequately pack the selection to avoid damage.
Check back often, as things get snapped up Ill add more!
#1 Tinted Door Glass $9.14 SOLD
#2 Tinted Vent Glass (Triangles) pair. $20.00 SOLD
#3 Wiper motor & linkage assembly $65.00
#4 R. bolt in sway bar brackets $9.14 SOLD
#5 License plate brackets (each, F. or R. early or late) $9.14 SOLD
#6 Center plastic deposit tray $9.14
#7 Fresh air blower motor $50.00
#8 Fresh air blower box $30.00
#9 Fresh air controls (late) $45.00
#10 Lightened (11.5lbs) Flywheel, PP & disc (gently used) $140.00 SOLD
#11 Pressure Plate & 4 spring clutch disk $75.00 SOLD
#12 Gauge Bezel (metal) $15.00
#13 Headlight surround (white early) single $9.14
#14 Headlight surround (black late) each $9.14
#15 Late window regulators R or L $30.00
#16 OE late tie rods (screw vs pinch) pair 15.00
#17 R. Trunk spring bars (pair) $9.14
#18 Steering Rack (w/o shaft) $35.00
#19 Gravel shields (each) $25.00
#20 Headlight covers (pair) $9.14
#21 Headlight Eyebrows (pair) $9.14
#22 Used 1.8 Piston set $9.14 SOLD
#23 Used 94mm Piston set (2.0L) $50.00 SOLD
#24 Targa Top storage Brackets (forward) per $9.14
#25 OE shifter (early or late) $30.00
#26 Gauge Cluster complete (early 120MPH, late 150MPH) $80.00
#27 Speedo's (early & late 150MPH only) $20.00 SOLD
#28 Fuel/Combo guages (early & late) $20.00
#29 Front hood (PU only) $75.00
#30 Shift boot (rubber) $9.14
#31 F. turn signal lenses (pair, used cond.) $9.14
#32 F. turn signal buckets (per) $15.00
#33 A. pillar trim (per side) $15.00
#34 B. Pillar trim (per side) $9.14
#35 Front brakes (each) $15.00
#36 Rear Brakes (Pair) $45.00
#37 Headlight relay cover (black) pair $9.14
#38 Eng. Lid Grill (per) $20.00
#39 Exhaust tip w/bung $25.00
#40 Speaker pods each $20.00
#41 Retractable (late) seat belt set $45.00
#42 Seat belt latch whip (late) per $9.14
#43 Seat belt latch whip (early) per $9.14
#44 Front hood latch set $20.00
#45 Rear Deck latch set $20.00
#46 Horn set (late, pair) $25.00
#47 Black 1.7 script $9.14
#48 Round relays (black) each $4.00
#49 Black door panel set (75-76 weave w/speakers) $75.00 SOLD
#50 Chrome headlight trim rings (pair) $9.14
#51 OE Blk headlight trim rings (pair) $15.00
#52 Pass. Rear .25 panel $50.00 SOLD
#53 Drvrs. Rear .25 panel $50.00 SOLD
#54 Set of decent tires (90%) 165x15 $35.00 SOLD
#55 Steering column 75-76 /4 $50.00
#56 Early Metal door latch bezels (pair) $25.00 SOLD
#57 Early Window Cranks (pair) $15.00 SOLD
#58 Side marker assemblies w/Lens (per side) $30.00
#59 Headlight Bucket assemblies (restored complete pair) $125.00
#60 Rear US lens (average shape. per.) $50.00
#61 Late /4 Boge strut housings (each) $9.14
#62 Trans Ground strap $9.14
#63 Bumper Dog bones (pair) $9.14
#64 1.8L FI harness (w/ injectors) $60.00 SOLD
#65 2.0L 912 Fuel Injectors (set of 4) $35.00 SOLD
#66 Glove box door /4 (early or late vinyl) $20.00
#67 Cam Gear $15.00
#68 Screw in Studs w/nuts (per)$1.00
#69 Transmission or early eng. mounts (NO cracks) Per. $15.00
#70 OE Valve covers Per. $10.00
#71 Alloy wheel lug bolts (Per.) $5.00
#72 Trunk Steel knockouts per $9.14
#73 Headlight bucket support steel per $9.14
#74 Aluminum Door thresholds (early, pair) $25.00 SOLD
#75 Black Plastic Door thresholds (late, pair) $20.00
#76 Interior Trim Plug set (all necessary to finish) $15.00 SOLD
#77 OE rear view mirror (early) $50.00 SOLD
#78 Leather Wheel Wrap $9.14
#79 Transmission Mount assemblies (complete pair) $40.00
#80 Complete wire loom (uncut) 72MY $75.00
#81 Aluminum Door *fuzzy* guides (pair) $20.00 SOLD
#82 Brake fluid reservoir assembly (w/lines) $35.00
#83 Cabin Fresh air vents (per) $9.14
#84 Fuel Tank assembly (early or late) $100.00
#85 Quad Tip Muffler (1.7-1.8L) $40.00 SOLD
#86 1.7-1.8L OE HE's (Good condition!) $40.00 SOLD
#87 Rain tray (late) $30.00
#88 Carb Fuel Pump (Faucet style)$20.00[/s]
#89 Holly fuel regulator (carb) $20.00
#90 Aluminum Trunk rollers $9.14 SOLD
#91 OE Shift knob $35.00
#92 Steering rack bellows $9.14
#93 Turbo Tie rod ends $30.00 SOLD
#94 Windshield (local PU only) $75.00 SOLD
#95 Lower dash pad(s) w/vents $25.00
#96 Lower dash pad (early no vents) $30.00
#97 Engine mount bar (Late sideshift) $30.00
#98 R. rubber bumper top (nice shape) $50.00 SOLD
#99 Heater fan outlet (Dual) $20.00 SOLD
#100 Heater fan outlet (single) $9.14
#101 Rear rubber bumper top (Very nice!) $85.00 SOLD
#102 BMW 320i calipers (REBUILT & PAINTED) $125.00 SOLD
#103 Period Blau AM radio $50.00 SOLD
#104 Steelie Hub Cap set (good shape) $50.00 SOLD
#105 Period Sapphire AM/FM radio w/ NOS faceplate $60.00 SOLD
#106 Rain Tray Drain Tubes (pair) $25.00
#107 Impeller Fan (Early or late, all fins intact) $40.00
#108 Heat Flapper valves (L or R) $35.00
#109 1.7 or 1.8 OE chrome muffler tip $9.14 SOLD
#110 OE Flywheel (fresh machining)$100.00 SOLD
#111 Bursch Muffler for all late 75-76 HE's (w/bypass pipe) $150.00 SOLD
#112 Muffler hanger for late 1.8 or 2.0L $9.14
#113 OE Muffler for 73-74 2.0L (Banana, VERY nice!) $250.00 SOLD
#114 Rear Trailing arm hubs (pair /4) $20.00
#115 Rear Trunk replacement steel panel $120.00 SOLD
#116 1.7 Throttle body & TPS $35.00 SOLD
#117 Center Deposit box (early) $35.00 SOLD
#118 Thermostat assembly (complete) $65.00 SOLD
#119 F. hood springs (pair) $9.14
#120 Map Pocket (Black) $25.00
#121 1.7L pre-heater tin assembly (rare!) $35.00
#122 Heat vents (Cabin under dash pair) $9.14
#123 Door latch assemblies (Int. pair) $35.00
#124 Door latch assemblies (Ext. per) $9.14
#125 Longitudinal tar long plugs (set of 4) $9.14
#126 "73" 2.0L FI D-Jet Brain $45.00 SOLD
#127 OE Trunk spring rollers (plastic) $9.14
#128 R. Tail panel section $60.00
#129 Windshield washer res. bottle (w/lines) $20.00
#130 .5 shafts (pair) $50.00
#131 Tank latch set $15.00
#132 Cabin access cover set $20.00
#133 Motor mount brackets (pair late) $25.00
#134 Fresh air valves (R or L per) $9.14
#135 Defrost Vent (R or L per) $9.14
#136 Insulted Long. heat tube (Per. ok cond.) $20.00 SOLD
#137 Tail shift shift-rod cover (front) $20.00 SOLD
#138 Targa top complete w/hardware $75.00
#139 Body plug set (front) $30.00
#140 E-Brake handle assembly (late) $45.00
#141 Seats, (Pair) late basket-weave cushions $150.00 SOLD
#142 Shift knob, leather & crest $30.00
#143 Exterior Door handles (no lock cyl.) $50.00
#144 Polyurethane Front bushings set (NOS 4 A-arms) $20.00 SOLD
#145 Eng. Bay Relay board (average cond.) $25.00
#146 Various Engine tin. per piece. (no 2.0L top) $9.14
#147 Side shift conversion parts (All, no trans-axle) $150.00
#148 Side shift trans-axle $250.00 SOLD
#149 Pass. Ext. Suspension console $55.00 SOLD
#150 Engine Case $75.00
#151 Muffler hanger for early 1.7 or 1.8L $9.14 SOLD
#152 Headlight Eyebrows grommets (set of 6) $9.14
#153 GT Engine Lid $125.00 SOLD
#154 Weltmeister A-Arm tab kit (NOS)$20.00 SOLD
#155 Flag Mirrors (pair) $9.14 SOLD
#156 Console heater lever (w/knob)$30.00[s] SOLD
#157 Carpet Pieces (per)$9.14
[s]#158 Dash switch set $55.00
SOLD
#159 Exterior Mirror (w/pad & screws)$50.00 SOLD
#160 Muffler Heat Shield $30.00
#161 Koni Red rears shocks w/progressive springs $125.00 SOLD
#162 Fresh air box plastic grate $25
#163 Complete fresh air box assembly $100.00 SOLD
#164 Rebuilt Pedal cluster $125.00
#165 901 transaxle tool (shaft or 1st/R. slider) $20.00 SOLD
#166 Front suspension PU $35.00
#167 Impeller to air inj. pulley mnt. $40.00 SOLD
#168 Tachometer gauge (early or late) $25.00 SOLD
#169 Defrost R. Window Glass $50.00
#170 Front trunk floor section (AC repair) $60.00 SOLD
#171 Formed Glove box (w/strap) $20.00
#172 Engine Windage tray/oil PU $30.00
#173 1.7L injectors (serviced by Witchhunter) $125.00 SOLD
#174 1.7L D-Jet FI harness $40.00
#175 Eng. Shroud flap assembly $35.00
#176 2.0L Rods (set of 4) $70.00
#177 OE Front steel valance $75.00
#178 Riviera wheels (Porsche offset, per) $30.00
#179 Empi wheels (set of 4) $140.00 SOLD
#180 Style Steel wheels (set of 4 w/good rubber & caps) $175.00 SOLD
#181 901 gear sets (inquire) $75.00
#182 901 Syncro rings (Good used, per) $30.00
#183 Air injection "spider" pipe $25.00
#184 Pass. (Int.) R. Suspension console $80.00 SOLD
#185 Drivers door panel (blk.) $50.00
#186 D-Jet Fuel Injection Pkg (76MY) $400.00
#187 Center tunnel section (complete w/all guide tubes intact) $150.00
#188 Late bumpers (75-76) per $40.00
#189 Seat cores (one pair, disassembled & boxed) $50.00
#190 Brake rotor set (used F. & R. w/ fresh turn) $80.00 SOLD
#191 OE Rear steel valance $100.00
#192 Heater fan (eng. bay Late) $30.00
#193 Targa top latches (Frt. & R) $30.00
#194 Air diverter's (eng. bay, pair) $30.00
#195 Washer switch (early /4 & /6) $20.00
#196 Speedometer angle drive $35.00
#197 Fresh air hose (plastic, pair) $20.00
#198 Relay board $25.00
#199 Alternator $40.00
#200 Visors (pair) $80.00
#201 Switch, R. window defrost $20.00
#202 Trailing Arm mounts $35.00
#203 Seat adjuster assemblies (per) $40.00
#204 Fog lights (pair, early) $50.00
#205 Back pad, Black (Avg. cond. ) $60.00
#206 Dry Sump oil pump (2 stage) $80.00 SOLD
what happened to the car?? is it for sale? thanks danny
STILL have a fuel pump for carbs??
Thanks
914werke
post Mar 21 2012, 10:02 PM
Post #99
QUOTE(MassTeener @ Mar 21 2012, 08:06 PM) *
STILL have a fuel pump for carbs?? Thanks
Sorry Gone.. (IMG:style_emoticons/default/dry.gif) I update the item listing ON THE 1st PAGE.
There is no value in reposting it for an inquiry, simply check that page first then reference the associated # (IMG:style_emoticons/default/confused24.gif)
I try to keep it updated but occasionally things slip by (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/popcorn[1].gif)
rgolia
post Mar 25 2012, 07:49 AM
Post #100
GeoJoe
I will take #32 turn signal buckets...if you have them
- Lo-Fi Version Time is now: 8th December 2025 - 10:39 PM
