A different way to hook up 911 e-brakes, Another way to do the 911 parkbrake -merged threads |
Wes V |
Oct 4 2008, 07:07 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I think I've come up with a totaly new way to hook up 911 parking brakes. It involves making up longer hybrid cables.
It's not complex, doesn't cost tons, and is about as straight forward as possible. It functions exactly as intended in the 911. Here is a teaser photo; (IMG:http://www.performanceforum.com/wesvann/914a/my-rear-brake/b-mrb1.jpg) Here is a link to my write-up on how I did it (it's a preliminary write-up). hybrid cables Wes (can somebody please find me the photo that I've seen on this site where somebody used a cable end block at the parking brake lever that had set screws) |
ClayPerrine |
Oct 6 2008, 09:53 PM
Life's been good to me so far..... Group: Admin Posts: 15,468 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I actually looked at the 924/944 solution. The mount for the cable is integral with the backing plate, and to use that backing plate would require way more modification than I am willing to do. Plus it puts the calipers behind the trailing arms, and they then hit the shock mount bolt.
The 944 shoes will fit the 911 backing plates. If someone made a mount to hold the expander and the end of the cable, it would work. But you are still left with custom cables. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:38 AM |
