A different way to hook up 911 e-brakes, Another way to do the 911 parkbrake -merged threads |
Wes V |
Oct 4 2008, 07:07 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I think I've come up with a totaly new way to hook up 911 parking brakes. It involves making up longer hybrid cables.
It's not complex, doesn't cost tons, and is about as straight forward as possible. It functions exactly as intended in the 911. Here is a teaser photo; (IMG:http://www.performanceforum.com/wesvann/914a/my-rear-brake/b-mrb1.jpg) Here is a link to my write-up on how I did it (it's a preliminary write-up). hybrid cables Wes (can somebody please find me the photo that I've seen on this site where somebody used a cable end block at the parking brake lever that had set screws) |
Wes V |
Oct 9 2008, 09:31 AM
Craig;
On the prior page, jcd914 posted a photo showing in green lines where the spreader would bear on the backing plate. The PET backing plate diagram I've seen has the spreader sitting on a raised area. In all disk brake installations, the shoes sit on raised sections. This is true on 911 backing plates and also on 924 backing plates. Now the question I've got (and hopefully you have a 924 backing plate you can look at) is if the raised pad supporting the spreader is at the same elevation as the pads that the shoes rest against. Wes V |
Lo-Fi Version | Time is now: 17th May 2024 - 11:38 PM |
