How many people need these ?, Targa roof to window top seal |
Mikey914 |
Oct 8 2008, 11:57 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Trying to gage need for these part #91453118510. These go on the roof and block water from comming in over the window. The part number is only for one side, but it would be both left and right.
I can do these without the plugs at about 22 a set, or plug at $17 each. If I have enough people that need these I'll make them. Thanks, Mark |
Richard Casto |
Oct 8 2008, 12:51 PM
I would take a set
Bruce Hinds |
Oct 8 2008, 01:44 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Trying to gage need for these part #91453118510. These go on the roof and block water from comming in over the window. The part number is only for one side, but it would be both left and right. I can do these without the plugs at about 22 a set, or plug at $17 each. If I have enough people that need these I'll make them. Thanks, Mark I can't picture the part you are talking about, do you have a picture? Bruce |
arvcube |
Oct 8 2008, 02:54 PM
Member Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 |
If these are the ones mounted to the sides of the Top and the top of the window butts up to them, then I need these badly.
Mikey914 |
Oct 8 2008, 07:24 PM
If these are the ones mounted to the sides of the Top and the top of the window butts up to them, then I need these badly. These Attached thumbnail(s) |
Mikey914 |
Oct 9 2008, 11:42 AM
Mark, I still don't know what you mean: 'with plugs' ... ((( or ))) ... 'without plugs' (IMG:style_emoticons/default/unsure.gif) The extrusion is the easy part, the end where the roof meets with the vertical targa seal on the roll bar is sealed, or "plugged" The OEM part uses a casting very similar to the vertical targa seal See Vertical targa seal The big problem I ran into with these is that the ends actually have a compound miter, and both sides are different, to manufacturing these ends was a tedious process that takes some labor to do, and I didn't have enough time to do them all, so the first sets that were purchased I made with the ends "plugged" ad opted to just sell the extrusion to try to recover some of my costs. This seal is different in that the cut is not compound and I can set up to do these faster. It will still take some time, but I will also sell the extrusion for those of you who can reuse your ends. Hope this helps to answer some questions. |
Howie's 914 |
Oct 11 2008, 09:35 PM
Member Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 |
I need a set also..
GaroldShaffer |
Oct 13 2008, 10:09 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I need a set also please.
TC 914-8 |
Oct 30 2008, 01:04 AM
Senior Member Group: Members Posts: 807 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Mark,
I have been looking for those exact peices. I'm in for a set, PM me or let me know they are ready for shipping. I think I bought a set of window/sail seals( The rubber running vertcal on the targa bar I cut to fit) from you, they worked great. Tony |
Mikey914 |
Oct 30 2008, 02:03 AM
These will be in late next week (first article) ready to ship following week. But, I will have a big surprise on Saturday I'll be posting.
arvcube |
Oct 30 2008, 09:31 AM
I've been waiting for these for a long time! (IMG:style_emoticons/default/w00t.gif)
big surprise...?!? |
TC 914-8 |
Nov 1 2008, 07:04 PM
Mikey914 |
Nov 1 2008, 09:06 PM
These will be in late next week (first article) ready to ship following week. But, I will have a big surprise on Saturday I'll be posting. It's Saturday Whats the suprise? 1/2 price? Just posted in Garage. 3 part seal repair. |
jsayre914 |
Nov 1 2008, 10:31 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Question?
when you roll up the window on the new seal. Where does the rubber go... outide the rubber , inside the rubber, or is there a channel that the window is supposed to go up into? reason for my question is that I got a set years back and half of it is inside and half of it is outide. this can also change depending on if the top was on befor the door was closed. (IMG:style_emoticons/default/dry.gif) |
Mikey914 |
Nov 2 2008, 11:45 PM
These will have a lip on the outdie edge and the window will roll up into the seal, same profile as OEM.
Mikey914 |
Nov 4 2008, 01:53 AM
Here's a profile for you.
okieflyr |
Nov 4 2008, 06:42 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I like the idea of being able to roll up the window into the seal, but what about when the window is all the way up and the door gets opened or shut? (IMG:style_emoticons/default/confused24.gif)
Mikey914 |
Nov 4 2008, 08:26 PM
I'll post you some pictures when I get them in next week.
TC 914-8 |
Nov 7 2008, 11:09 AM
Mikey914 |
Nov 8 2008, 09:16 AM
These are the same profile as factory. I didn't see the need to get too exotic here. The originals worked, so why not use the same basic shape.
Lo-Fi Version | Time is now: 28th April 2024 - 01:41 AM |
