Mikey914
Oct 8 2008, 11:57 AM
Trying to gage need for these part #91453118510. These go on the roof and block water from comming in over the window. The part number is only for one side, but it would be both left and right.
I can do these without the plugs at about 22 a set, or plug at $17 each. If I have enough people that need these I'll make them.
Thanks,
Mark
Richard Casto
Oct 8 2008, 12:51 PM
I would take a set
Bruce Hinds
Oct 8 2008, 01:44 PM
QUOTE(Mikey914 @ Oct 8 2008, 10:57 AM)
Thanks,
Mark
I can't picture the part you are talking about, do you have a picture?
Bruce
arvcube
Oct 8 2008, 02:54 PM
If these are the ones mounted to the sides of the Top and the top of the window butts up to them, then I need these badly.
Mikey914
Oct 8 2008, 07:24 PM
QUOTE(arvcube @ Oct 8 2008, 01:54 PM)
These
Mikey914
Oct 9 2008, 11:42 AM
QUOTE(euro911 @ Oct 9 2008, 09:31 AM)
Mark,
I still don't know what you mean:
with plugs' ... ((( or ))) ... '
without plugs'
The extrusion is the easy part, the end where the roof meets with the vertical targa seal on the roll bar is sealed, or "plugged" The OEM part uses a casting very similar to the vertical targa seal See
Vertical targa sealThe big problem I ran into with these is that the ends actually have a compound miter, and both sides are different, to manufacturing these ends was a tedious process that takes some labor to do, and I didn't have enough time to do them all, so the first sets that were purchased I made with the ends "plugged" ad opted to just sell the extrusion to try to recover some of my costs.
This seal is different in that the cut is not compound and I can set up to do these faster. It will still take some time, but I will also sell the extrusion for those of you who can reuse your ends.
Hope this helps to answer some questions.
Howie's 914
Oct 11 2008, 09:35 PM
I need a set also..
GaroldShaffer
Oct 13 2008, 10:09 PM
I need a set also please.
TC 914-8
Oct 30 2008, 01:04 AM
Mark,
I have been looking for those exact peices. I'm in for a set, PM me or let me know they are ready for shipping. I think I bought a set of window/sail seals( The rubber running vertcal on the targa bar I cut to fit) from you, they worked great.
Tony
Mikey914
Oct 30 2008, 02:03 AM
These will be in late next week (first article) ready to ship following week. But, I will have a big surprise on Saturday I'll be posting.
arvcube
Oct 30 2008, 09:31 AM
I've been waiting for these for a long time!
big surprise...?!?
TC 914-8
Nov 1 2008, 07:04 PM
QUOTE(Mikey914 @ Oct 30 2008, 01:03 AM)
It's Saturday Whats the suprise? 1/2 price?
Mikey914
Nov 1 2008, 09:06 PM
QUOTE(TC 914-8 @ Nov 1 2008, 06:04 PM)
Just posted in Garage. 3 part seal repair.
jsayre914
Nov 1 2008, 10:31 PM
Question?
when you roll up the window on the new seal. Where does the rubber go...
outide the rubber , inside the rubber, or is there a channel that the window is supposed to go up into?
reason for my question is that I got a set years back and half of it is inside and half of it is outide. this can also change depending on if the top was on befor the door was closed.
Mikey914
Nov 2 2008, 11:45 PM
These will have a lip on the outdie edge and the window will roll up into the seal, same profile as OEM.
Mikey914
Nov 4 2008, 01:53 AM
Here's a profile for you.
okieflyr
Nov 4 2008, 06:42 PM
I like the idea of being able to roll up the window into the seal, but what about when the window is all the way up and the door gets opened or shut?
Mikey914
Nov 4 2008, 08:26 PM
I'll post you some pictures when I get them in next week.
TC 914-8
Nov 7 2008, 11:09 AM
QUOTE(Mikey914 @ Nov 4 2008, 06:26 PM)
Mike, I'm still in for whatever you come up with.
Mikey914
Nov 8 2008, 09:16 AM
These are the same profile as factory. I didn't see the need to get too exotic here. The originals worked, so why not use the same basic shape.
johnsorr
Nov 11 2008, 06:54 AM
I need these.
paroxysm
Nov 12 2008, 06:39 PM
I'd like a set
lucky25
Nov 19 2008, 09:22 AM
I would like a set when ready
Mikey914
Nov 19 2008, 11:09 PM
Here's pictures of the fitted pieces. you can see from the first picture how the seal allows the glass across the first lip and that's the first barrier, it also touches the back of the glass.
the original seals had a hole drilled into the extrusion for a screw that kept the extrusion from sliding around. This is a tight fit and I do not believe that it will be necessary. The parts is shown with a hand cut piece of rubber that's glued onto the extrusion. I'm actually having the ends water jet cut for a more presise fit and more finished look these will be done next week. I'm planning to start shipping these after the Thanksgiving weekend. I'll be contacting all this weekend to confirm orders.
I hope this answers some of the questions on how the seal will work. Unfortunately these will install like OEM, the outside is fitted into the track and the inside is pushed in 1/4" at a time. I used a butter knife, but if anyone has any better ideas of how the OEM seals would install easier I'm sure it would work on these also.
Thanks All.
Mikey914
Nov 19 2008, 11:14 PM
More
TC 914-8
Dec 4 2008, 11:53 PM
Hi Mark, Any word on the ship dates?
charliew
Dec 5 2008, 01:44 PM
I also need a set. They look good.
LetoAtreides
Dec 17 2008, 10:59 PM
I need a set as well. Nice work.
