How many people need these ?, Targa roof to window top seal |
Mikey914 |
Oct 8 2008, 11:57 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Trying to gage need for these part #91453118510. These go on the roof and block water from comming in over the window. The part number is only for one side, but it would be both left and right.
I can do these without the plugs at about 22 a set, or plug at $17 each. If I have enough people that need these I'll make them. Thanks, Mark |
jsayre914 |
Nov 1 2008, 10:31 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Question?
when you roll up the window on the new seal. Where does the rubber go... outide the rubber , inside the rubber, or is there a channel that the window is supposed to go up into? reason for my question is that I got a set years back and half of it is inside and half of it is outide. this can also change depending on if the top was on befor the door was closed. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:23 AM |
