How many people need these ?, Targa roof to window top seal |
Mikey914 |
Oct 8 2008, 11:57 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Trying to gage need for these part #91453118510. These go on the roof and block water from comming in over the window. The part number is only for one side, but it would be both left and right.
I can do these without the plugs at about 22 a set, or plug at $17 each. If I have enough people that need these I'll make them. Thanks, Mark |
Mikey914 |
Nov 19 2008, 11:09 PM
Here's pictures of the fitted pieces. you can see from the first picture how the seal allows the glass across the first lip and that's the first barrier, it also touches the back of the glass.
the original seals had a hole drilled into the extrusion for a screw that kept the extrusion from sliding around. This is a tight fit and I do not believe that it will be necessary. The parts is shown with a hand cut piece of rubber that's glued onto the extrusion. I'm actually having the ends water jet cut for a more presise fit and more finished look these will be done next week. I'm planning to start shipping these after the Thanksgiving weekend. I'll be contacting all this weekend to confirm orders. I hope this answers some of the questions on how the seal will work. Unfortunately these will install like OEM, the outside is fitted into the track and the inside is pushed in 1/4" at a time. I used a butter knife, but if anyone has any better ideas of how the OEM seals would install easier I'm sure it would work on these also. Thanks All. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 07:04 AM |
