How many people need these ?, Targa roof to window top seal |
johnsorr |
Nov 11 2008, 06:54 AM
Newbie Group: Members Posts: 1 Joined: 22-August 05 From: Neenah, WI Member No.: 4,637 |
I need these.
paroxysm |
Nov 12 2008, 06:39 PM
Member Group: Members Posts: 80 Joined: 4-April 04 From: chilliwack bc canada Member No.: 1,888 |
I'd like a set
lucky25 |
Nov 19 2008, 09:22 AM
Newbie Group: Members Posts: 45 Joined: 11-October 08 From: Upland, Ca. Member No.: 9,635 Region Association: Southern California |
I would like a set when ready
Mikey914 |
Nov 19 2008, 11:09 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Here's pictures of the fitted pieces. you can see from the first picture how the seal allows the glass across the first lip and that's the first barrier, it also touches the back of the glass.
the original seals had a hole drilled into the extrusion for a screw that kept the extrusion from sliding around. This is a tight fit and I do not believe that it will be necessary. The parts is shown with a hand cut piece of rubber that's glued onto the extrusion. I'm actually having the ends water jet cut for a more presise fit and more finished look these will be done next week. I'm planning to start shipping these after the Thanksgiving weekend. I'll be contacting all this weekend to confirm orders. I hope this answers some of the questions on how the seal will work. Unfortunately these will install like OEM, the outside is fitted into the track and the inside is pushed in 1/4" at a time. I used a butter knife, but if anyone has any better ideas of how the OEM seals would install easier I'm sure it would work on these also. Thanks All. Attached thumbnail(s) Attached image(s) |
Mikey914 |
Nov 19 2008, 11:14 PM
More
TC 914-8 |
Dec 4 2008, 11:53 PM
Senior Member Group: Members Posts: 807 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Hi Mark, Any word on the ship dates?
charliew |
Dec 5 2008, 01:44 PM
I also need a set. They look good.
LetoAtreides |
Dec 17 2008, 10:59 PM
Member Group: Members Posts: 86 Joined: 15-May 07 From: Half Moon Bay, California Member No.: 7,739 Region Association: None |
I need a set as well. Nice work.
Lo-Fi Version | Time is now: 27th April 2024 - 02:09 PM |
