Stall speed ? |
Stall speed ? |
scotty b |
Oct 8 2008, 07:10 PM
Can anyone here explain ( In dum painter terms ) the stall speed, in depth and how it comes into play when looking at cam shafts ?
Spank you |
stepuptotheMike |
Oct 8 2008, 07:54 PM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
and while you are at it..... what it means in reference to torque converters. (IMG:style_emoticons/default/biggrin.gif)
-Mike |
ws91420 |
Oct 8 2008, 08:02 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Stall speed is the speed at which the converter will hold back the engine output if the the transmission output is prohibited. Drag racers typically want a high stall converter to build up more rpms for off the line launch
so probably for knowledge if it will be held at x rpm for a while |
scotty b |
Oct 8 2008, 08:05 PM
Stall speed is the speed at which the converter will hold back the engine output if the the transmission output is prohibited. Drag racers typically want a high stall converter to build up more rpms for off the line launch so probably for knowledge if it will be held at x rpm for a while So for a top end cam you would want a higher stall speed converter ? Or is that to simple ? |
ws91420 |
Oct 8 2008, 08:15 PM
here is an article that should answer your questions
http://www.chevyhiperformance.com/techarti...dyno/index.html |
scotty b |
Oct 8 2008, 08:24 PM
Thanks Welby, that does help. (IMG:style_emoticons/default/beerchug.gif) I have a feeling the Chrysler has a high stall converter in it now. It is pretty sluggish at low speed and doesn't take off well when easing on the gas. Like the clutches are slipping. But when you get on it and the RPM jumps so does the car. (IMG:style_emoticons/default/biggrin.gif) I'm trying to figure out what cam to go with and knew somehow the stall speed played into it. Now I know...and knowing is half the battle
degreeoff |
Oct 8 2008, 08:57 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Ummmm....in a cessna its about 47 knots dirty and 60 clean....give or take depending on weight
plas76targa |
Oct 8 2008, 09:32 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
now be specific Josh. C150, C152, c172, c182, c210, C404 ???
(IMG:style_emoticons/default/drunk.gif) |
dflesburg |
Oct 8 2008, 09:36 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
If you don't push in the clutch, somewhere around 10 mph.
sww914 |
Oct 8 2008, 09:47 PM
I stall out at about 3:30.
fiid |
Oct 9 2008, 03:31 AM
In the 172SP it's 40 KIAS dirty at max gross and 48 KIAS clean at max gross with most forward center of gravity.
KIAS isn't to do with Korean cars - it's the airspeed indicated in knots. Perhaps more interesting is that the "Do Not Exceed" speed of a 172SP is 163 KIAS, which according to the operating handbook is exactly the same as the "Maximum Window Open Speed". I want to know how they engineered the windows to break at exactly the same speed as the wings (IMG:style_emoticons/default/smile.gif) BTW - the 172SP is my other ride powered by an air cooled flat 4. Passed my private checkride about a month ago... (IMG:style_emoticons/default/smile.gif) |
plas76targa |
Oct 9 2008, 08:22 AM
(IMG:style_emoticons/default/bye1.gif) hi Fiid! (we met at McMarks' gee 3+ years ago) Congrats on check ride.
and sorry to Hijack your thread Scotty. did you get your real answer on stall speed - related to auto transmission? |
Oct 9 2008, 11:34 AM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
messix |
Oct 9 2008, 12:53 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what chrysler are you talking about?
is this something that has allways been that way or has it just started? is this car new to you, is stock or modified/hot rodded? transmission problems came show up like what you have discribed. |
scotty b |
Oct 9 2008, 07:08 PM
what chrysler are you talking about? is this something that has allways been that way or has it just started? is this car new to you, is stock or modified/hot rodded? transmission problems came show up like what you have discribed. 68 300, It has been in my possession for a little over a year, sat for a while prior to that, and has done this all along. I am fairly certain it is a tranny problem but I am planning to go throught the engine and trans over winter and will be installing a cam. I figure while I have everything apart I will try to figure out what stall speed would be best suited for the car. But I'm not gud wif figgering owt dat tipe uv stuffs |
jmill |
Oct 9 2008, 09:17 PM
Comp cams has a sweet website where you can download a program to select the right cam for you car.
http://www.compcams.com/camquest/default.asp It will recommend the correct stall speed converter for the cam you select. |
ClayPerrine |
Oct 9 2008, 09:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
In the 172SP it's 40 KIAS dirty at max gross and 48 KIAS clean at max gross with most forward center of gravity. KIAS isn't to do with Korean cars - it's the airspeed indicated in knots. Perhaps more interesting is that the "Do Not Exceed" speed of a 172SP is 163 KIAS, which according to the operating handbook is exactly the same as the "Maximum Window Open Speed". I want to know how they engineered the windows to break at exactly the same speed as the wings (IMG:style_emoticons/default/smile.gif) BTW - the 172SP is my other ride powered by an air cooled flat 4. Passed my private checkride about a month ago... (IMG:style_emoticons/default/smile.gif) Ok.. you know what VNE is for the Cessna 172. What is VOS???? |
Eric_Shea |
Oct 9 2008, 10:11 PM
QUOTE easing on the gas There's your problem. Put that damn cross-ram in there I found for ya and help stimulate the economy!! (IMG:style_emoticons/default/w00t.gif) |
championgt1 |
Oct 9 2008, 10:54 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Dr Evil |
Oct 9 2008, 11:14 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am rebuilding my first auto trans and it is way easier than a manual. Maybe you need it redone. Look into a kit and I can do it for ya.
Lo-Fi Version | Time is now: 21st May 2024 - 01:58 PM |
