Creamsicle resto thread- A little sad tonight, Sold & loaded on a trailer! Headed to Florida to Tommy |
JRust |
Oct 12 2008, 03:00 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Hey I came across a 914 for sale. I talked with the guy on the phone & he says it's a 73 2.0 car. It was in dry storage for a while but he couldn't find any rust. BOth trunks look good & he says below the battery there is NO Rust. I know I will believe that when I see it myself. Still I asked him to send me some pictures. I see bumper tits on the front bumper & know it's a 74. I also see Mahle wheels & an LE front spoiler (IMG:style_emoticons/default/idea.gif) . Car runs & shifts great too! The side stripe isn't the right color for an LE though right?
How can I find out if it is an LE? Vin#? Then where would I find LE vins? Attached image(s) |
JRust |
Oct 19 2008, 12:01 AM
I don't think it had a spliced section. I really think something cause the cut where they welded. Not sure how but even the weld does not go from the bottom you see all the way to the fron where the brass is. There is a couple inches with no weld between the bottom weld & where the top brass is. I've got a good body guy in mind. He helped me with the restoration of my 73 8 years ago. Not sure if he is still around. I've got to see monday if he is where he was then. I will get this fixed & soon.
scotty b |
Oct 19 2008, 09:31 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I don't think it had a spliced section. I really think something cause the cut where they welded. Not sure how but even the weld does not go from the bottom you see all the way to the fron where the brass is. There is a couple inches with no weld between the bottom weld & where the top brass is. I've got a good body guy in mind. He helped me with the restoration of my 73 8 years ago. Not sure if he is still around. I've got to see monday if he is where he was then. I will get this fixed & soon. Ah I couldn't tell there were spots with no weld. In that case it was probably hit and to pull it out it was just cut, pulled back closely by hand then re-welded. The brass may have been used to fill in some deep depressions or possibly to fill in where there was a gap. Back to the issue at hand. If you can get hold of a welder, get the panel as close as possible then you could cut out some of the nastier sections and make some patches to clean it up if you so desire. (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 04:14 PM |
