914 Engine Code, Finally found mine. |
Trav012000 |
Oct 13 2008, 11:43 AM
Member Group: Members Posts: 59 Joined: 23-September 08 From: Indiana, USA Member No.: 9,583 Region Association: Upper MidWest |
I purchased my 914 off ebay and was told by the seller that the engine was "probably" a Van engine. Likely a 1.7L. Well for the past month I've been trying to track down the engine code when finally today I did get it.
GC003400 I looked up and it's listed as a 2000cc engine that comes with the 75/76 914s. Now I've got a '76 porsche that was built in late '75. I was under the impression that all '76 models came with a fuel injected engine. I also thought they all came with the center console but mine came with neither. Can anyone clear this up? |
Oct 13 2008, 12:15 PM
I was under the impression that all '76 models came with a fuel injected engine. Yes. All (USA) 1.7L and 2.0L came with D-Jet, all 1.8L came with L-Jet. No 914 on this side of the atlantic was delivered with carbs, if you have carbs, someone other than the factory put them on there. As for your engine, GC003400, both '75 and '76 were the same internally: 1975: 914/4, 1971cc, 2.0L, GC, USA, 88HP @ 4900rpm, Stroke/Bore: 71/94, Compression: 7.6:1, D-Jetronic, 914/12 1976: 914/4, 1971cc, 2.0L, GC, USA, 88HP @ 4900rpm, Stroke/Bore: 71/94, Compression: 7.6:1, D-Jetronic, 914/12 http://www.914world.com/specs/engnumbs.php (IMG:style_emoticons/default/bye1.gif) Andy |
Todd Enlund |
Oct 13 2008, 12:51 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I purchased my 914 off ebay and was told by the seller that the engine was "probably" a Van engine. Likely a 1.7L. Well for the past month I've been trying to track down the engine code when finally today I did get it. GC003400 I looked up and it's listed as a 2000cc engine that comes with the 75/76 914s. Now I've got a '76 porsche that was built in late '75. I was under the impression that all '76 models came with a fuel injected engine. I also thought they all came with the center console but mine came with neither. Can anyone clear this up? These cars are old enough now that what's what can be a bit muddy... I just bought an engine that was a combination of 1.8L bus case, 2.0L bus pistons/cylinders, 2.0L 914 heads and a 2.0L crank from one or the other. The guy that I got it from only knew what the heads were... I had to open it to verify the pistons and crank. You've got a 2.0 case, which is a good sign that the engine is a 2.0, but check your heads to see if they have three or four studs on the intake manifold. Three is a 2.0L 914 head, four is "something else". |
Trav012000 |
Oct 13 2008, 02:15 PM
Thanks for the info. So regardless, I've got a 914 engine, unclear whether it's the original, but definitely converted from D-Jet. Though it could have all manner of parts in it. (IMG:style_emoticons/default/smile.gif)
Thanks for clearing that up. |
Trav012000 |
Oct 13 2008, 02:37 PM
Okay, one more question. How about the transmission. How would I be able to tell if it's a sportmatic or not? In the engine bay there's a "925" in white letters. I did a search for that and it came up with it being sportmatic, but I'm thinking the 925 listed there is something else.
http://i24.ebayimg.com/01/i/001/05/b7/a2fb_3.JPG You can see the 925 at the bottom of the picture. |
Oct 13 2008, 02:43 PM
How would I be able to tell if it's a sportmatic or not? You got a clutch pedal? If so, it's *not* a sportomatic ... (IMG:style_emoticons/default/shades.gif) Andy |
JeffBowlsby |
Oct 13 2008, 03:15 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
“925” means
GC code engine 49-state |
Cupomeat |
Oct 13 2008, 03:45 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
As for the center console.
Toward the end of the 914 run, most items were made to be options, so no, not all 75/76 2.0l came with a center console. |
Trav012000 |
Oct 13 2008, 04:14 PM
Thanks again guys. Somehow I missed the whole Sportomatic = Automatic.
Curse of being a computer guy that could fix anything and trying to get at least half as good with cars. It's a learning curve. (IMG:style_emoticons/default/tongue.gif) |
orange914 |
Oct 13 2008, 04:54 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
but check your heads to see if they have three or four studs on the intake manifold. Three is a 2.0L 914 head, four is "something else". hopefully you have the 3 stud (IMG:style_emoticons/default/beerchug.gif) what part of indiana you at? mike |
Lo-Fi Version | Time is now: 21st May 2024 - 11:34 AM |
