Clutch Wear, How To Determine If worn? |
Spoke |
Oct 14 2008, 08:10 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I am hoping to use one of the 2 clutch plates that I have for my 71 1.7L.
Reading the repair manual, the only measurement mentioned is 0.6mm depth for the rivets. THere's no cracking or oil staining on either plate. I've estimated the depth on the one plate to be about 1.8mm and the other to be about 2.0mm. One plate has slots and one does not. Does mean the one w/o slots is worn more or are there both types (w/slots and w/o slots) out there? What other criteria should I use to evaluate the clutch plates for continued use? Attached image(s) |
Gint |
Oct 14 2008, 08:12 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Why don't I move this thread to the garage instead of the classifieds?
orange914 |
Oct 14 2008, 08:28 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
check the spring tension and deglaze the material (IMG:style_emoticons/default/beerchug.gif) good to go imho
Spoke |
Oct 15 2008, 12:22 PM
Thanks. what method to deglaze the plates? Steel wool? Fine Sandpaper? What about the PP & flywheel? Deglaze those?
orange914 |
Oct 15 2008, 04:32 PM
Thanks. what method to deglaze the plates? Steel wool? Fine Sandpaper? What about the PP & flywheel? Deglaze those? just ruff up the slick/glazed material face with an abrasive pad of sorts, i always used a small orbital scotchbrite pad on my high speed die grinder or drill to cut the glaze on the flywheel and brake rotors/disc. it would take real effort but be careful not to dig in. it even looks "machine fresh" after you do it a couple times (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Oct 16 2008, 12:30 AM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Der fine der, dont cha know. They are two different types, both will work, use the 2.0mm one.
Wilhelm |
Oct 16 2008, 12:44 AM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
In a similar vein and not meant to hijack......... I've got about a dozen pressure plates I got in some deal. Are there any sort of criteria to decide if these are good or just recycle material?
jimkelly |
Oct 16 2008, 03:36 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
clutch disc is only $68 from pelican - i would say just replace it.
http://www.pelicanparts.com/catalog/shopca...c_pg1.htm#item7 jim |
Lo-Fi Version | Time is now: 26th May 2024 - 03:17 PM |
