Projekt: 914 GT4, Everyone needs a build thread... |
Todd Enlund |
Oct 22 2008, 04:41 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Everyone needs a build thread, right? Here’s mine. I am going to post the first part of this retroactively, and then I’ll try to keep it updated.
I got the car as a trade for services. A guy that I knew had 5½ 914s, and was getting married. I agreed to photograph his wedding in exchange for a 914 and a 901 sideshifter. Barter is good. My plan was originally to do a Subaru conversion, but I decided that to do it right would cost too much, and I had just been forced to retire from the Air Force two days before my 43rd birthday. The budget will be tight. I considered a 2.7/6 conversion, but again, the little things would add up to be expensive. Over the last year, my plan has evolved. I decided to stick with a Type IV, and rebuild it myself. The factory color is L21E Tangerine, and I plan on an updated M471-style GT look. Small parts will kill a budget, so many of my decisions will be based on NOT buying or restoring parts to factory condition, but still having a solution that looks like I did not compromise. My goal is 1900 lbs, 150 HP and LOTS of fun. Here is my inspiration: |
J P Stein |
Jan 7 2009, 11:09 AM
I like Dan Hall's. It looks & smells like a machine shop should. The folks there have dirt under their finger nails.
Don't forget, YOU are responsible for cleaning out the oil passages in your crank after grind/polish. Clean till you're cross-eyed, then do it summore. |
Todd Enlund |
Jan 7 2009, 11:19 AM
I like Dan Hall's. It looks & smells like a machine shop should. The folks there have dirt under their finger nails. Don't forget, YOU are responsible for cleaning out the oil passages in your crank after grind/polish. Clean till you're cross-eyed, then do it summore. They told me that they would clean it, but I plan on re-cleaning it when I get it, and I also plan on cleaning every single part immediately before it goes in my engine. I'm still working on cleaning the case... it looks clean, it's nice and shiny, but it doesn't feel clean. |
J P Stein |
Jan 7 2009, 06:02 PM
I like Dan Hall's. It looks & smells like a machine shop should. The folks there have dirt under their finger nails. Don't forget, YOU are responsible for cleaning out the oil passages in your crank after grind/polish. Clean till you're cross-eyed, then do it summore. They told me that they would clean it, but I plan on re-cleaning it when I get it, and I also plan on cleaning every single part immediately before it goes in my engine. I'm still working on cleaning the case... it looks clean, it's nice and shiny, but it doesn't feel clean. They never said anything about cleaning out any of the cranks I took there.....and they were definately not clean. I spent hours squirting clean solvent ...pipe cleaners, Q tips....whut ever... thru the suckers till they ran free of shittage. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:40 PM |
