Projekt: 914 GT4, Everyone needs a build thread... |
Todd Enlund |
Oct 22 2008, 04:41 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Everyone needs a build thread, right? Here’s mine. I am going to post the first part of this retroactively, and then I’ll try to keep it updated.
I got the car as a trade for services. A guy that I knew had 5½ 914s, and was getting married. I agreed to photograph his wedding in exchange for a 914 and a 901 sideshifter. Barter is good. My plan was originally to do a Subaru conversion, but I decided that to do it right would cost too much, and I had just been forced to retire from the Air Force two days before my 43rd birthday. The budget will be tight. I considered a 2.7/6 conversion, but again, the little things would add up to be expensive. Over the last year, my plan has evolved. I decided to stick with a Type IV, and rebuild it myself. The factory color is L21E Tangerine, and I plan on an updated M471-style GT look. Small parts will kill a budget, so many of my decisions will be based on NOT buying or restoring parts to factory condition, but still having a solution that looks like I did not compromise. My goal is 1900 lbs, 150 HP and LOTS of fun. Here is my inspiration: |
Todd Enlund |
Jan 13 2009, 12:08 PM
I could see the bead okay, but seeing where I was going was a bit iffy. Next time for practice, I am going to cut two pieces and try to follow the seam.
From looking at my initial attempt, I feel like I need to move a little faster, and I burned through at the end of the bead. |
strawman |
Jan 13 2009, 06:10 PM
Senior Member Group: Validating Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I could see the bead okay, but seeing where I was going was a bit iffy. Next time for practice, I am going to cut two pieces and try to follow the seam. From looking at my initial attempt, I feel like I need to move a little faster, and I burned through at the end of the bead. Be sure to get way down low and bring the bead toward you so that you can see what going on... sometimes the MIG gun or something else blocks your view when welding on the car, but practice/practice/practice beforehand will give you a better feel for hand speed, angle of the gun, motion of the gun (straight, half-moons, etc.), distance of the gun from the metal, etc. Soap pencils parallel to the weld area can also help when you're welding in an area with low-light. Have fun! (IMG:style_emoticons/default/welder.gif) Geoff |
Lo-Fi Version | Time is now: 21st May 2024 - 06:26 PM |
