gettin real tired of crappy shifting, anybody else in this boat |
pete-stevers |
Oct 25 2008, 09:25 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
first off i would like to shoot the engineer who designed the shifting system
, by firing squad... and none of the squad would have blanks..... (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) now that i have that out of the way..... i am having a bitch of a time getting my shifting in order. i can not get reverse and i can not get fourth and fifth i have a jwest shifter which helps a quite a bit, but i believe the problem.. er problems to be linkage related.... i know a few of you have linkage kits of sorts...would you chime in a let me know of your trials, errors , and succeses thanks guys |
southernmost914 |
Oct 25 2008, 09:36 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Tail shiht or side shifht?
Steve |
SGB |
Oct 25 2008, 09:42 PM
I was looking at James' stuff last weekend. It is VERY close tolerance work. Did you get the two piece shift rod that has the enhanced (two bushing) locating assembly built into the rear shift console? It looked like that would be necessary. James did say some folks did not buy the jointed shift rod, though. The stock setup depends on some bushing slop at the firewall and the shift console. I'm guessing at least part of that ain't very sloppy no more.
Oct 25 2008, 10:15 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i can not get reverse and i can not get fourth and fifth You need to adjust the shifter correctly. Has nothing to do with the JWest parts. The rod the goes into the bottom of the shifter needs to be adjusted right. Don't blame the engineer, blame the operator! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Andy |
McMark |
Oct 25 2008, 10:42 PM
Could also be a bent shift rod. I've seen one of those. Ask Jgara about it.
pete-stevers |
Oct 25 2008, 11:10 PM
i can not get reverse and i can not get fourth and fifth You need to adjust the shifter correctly. Has nothing to do with the JWest parts. The rod the goes into the bottom of the shifter needs to be adjusted right. Don't blame the engineer, blame the operator! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Andy nope. andy the shifter is a work of art...... i am learning how to adjust by trial and error ..lets talk about shift linkage mods.....i know you did extensive work with the jwest kit, inlcluding a comprehensive thread...perhaps you could post a link |
pete-stevers |
Oct 25 2008, 11:11 PM
and this could be a bent shift rod....because the tolerances are not really that bad at any point...so far....
Bruce Hinds |
Oct 25 2008, 11:14 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
make sure you have good bushings, no slop in the rods where they meet at the firewall and then it's just a matter if a finite adjustment. Believe me, a minor adjustment makes a big difference.
If you can't get reverse and fifth, you've got some slop somewhere. B |
pete-stevers |
Oct 25 2008, 11:39 PM
i can not get reverse and i can not get fourth and fifth You need to adjust the shifter correctly. Has nothing to do with the JWest parts. The rod the goes into the bottom of the shifter needs to be adjusted right. Don't blame the engineer, blame the operator! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Andy Andy could you let me know how to do basic adjustments..... but for starters the shifter was working great and then a week ago the shifting seemed to get worse, so i doubt it is an issue with shifter...and rather somthing down the line i am of the mindset to replace all of the bushings and linkage with something a little more "skookum" (that is a canadian way of saying "bigger and better") |
Oct 26 2008, 12:16 AM
for starters the shifter was working great and then a week ago the shifting seemed to get worse, so i doubt it is an issue with shifter...and rather somthing down the line That's usually the cone screw on the shifter coupler right after the firewall coming lose. (IMG:style_emoticons/default/bye1.gif) Andy |
Dr Evil |
Oct 26 2008, 12:20 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
In my tranny rebuild link you will find a list of things to check (IMG:style_emoticons/default/smile.gif)
Gint |
Oct 26 2008, 11:02 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That's usually the cone screw on the shifter coupler right after the firewall coming lose. (IMG:style_emoticons/default/bye1.gif) Andy Or the bushings in the shift coupler going south. Just replaced mine a couple of weeks ago for the same reason. You need to get under the car Steve and check every bushing. I'm quite pleased with the shifting on my car even with the stock shifter. |
pete-stevers |
Oct 26 2008, 12:00 PM
i have half a mind to split for the j west linkage kit...
the only problem i have is the engine sits one inch lower so i may ask them to modify a bar for me as well, as the straight bar will not quite clear.... |
SGB |
Oct 26 2008, 11:19 PM
That split rod with console locating mod looked very precise. It really does sound like a bushing is deteriorationg somewhere to me.
Tom |
Oct 27 2008, 10:05 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Pete-stevers,
Check out the thread I did on shifter bushings. May give you some help. Tom http://www.914world.com/bbs2/index.php?showtopic=72473 |
sean_v8_914 |
Oct 27 2008, 10:20 PM
cone screw on the trans console
sean_v8_914 |
there is nothing wrong with the 914 shifter system
pete-stevers |
Oct 28 2008, 07:57 PM
there is actually little wrong with the sys, jsut a few loose screws and few looser bushings....and my state of mind that day,
i am going to tackle the job early thurs morning after a big cup of coffee ... turn on some tunes, and get my forehead annoited with the drips of 50/20 on the bottom of my beloved 3.0 i need to get it sorted for a drive down to Dan Roots to to get a few flares welded on.... but i will be buying the full set up from jwest....to install at a later date.... |
pete-stevers |
Oct 30 2008, 08:59 PM
for starters the shifter was working great and then a week ago the shifting seemed to get worse, so i doubt it is an issue with shifter...and rather somthing down the line That's usually the cone screw on the shifter coupler right after the firewall coming lose. (IMG:style_emoticons/default/bye1.gif) Andy yup you where dead on Andy! thanks now i can wait until the canuck buck corrects a bit before shelling out for the kit. |
Lo-Fi Version | Time is now: 4th June 2024 - 10:19 AM |
