2056 Setup, What to do?? Fuel Delivery |
7275914911 |
Oct 27 2008, 02:42 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I'm putting together a 2056 as stated in the title. What are you people running as a fuel delivery system and are you pleased?
I have been told the BEST setup would be SDS, M-Unilite and MSD 6A or AL. Are the people using this setup pleased with it? I have a L-Jet system on my 1.8 at the present. With some modification (most expensive of which would be 912 injectors it seems) I am tempted to run this setup. My problem is I plan on keeping and rebuilding my 1.8 and am wondering if modification of the PCV system would be irreversable? Motor has 9550 Raby cam so I know it is best suited for FI and not carbs. I have to believe the carbs are the cheap way to go though maybe not the best. What will I lose with a carb setup and what size carbs should I be looking at. Also have a question on what type of exhaust you guys are running and is it getting you more HP? Will have MSDS header and 911 muffler but can I do better? Thanks for all replies (IMG:style_emoticons/default/popcorn[1].gif) JKP |
Lo-Fi Version | Time is now: 26th May 2024 - 09:58 AM |
