I'm putting together a 2056 as stated in the title. What are you people running as a fuel delivery system and are you pleased?
I have been told the BEST setup would be SDS, M-Unilite and MSD 6A or AL. Are the people using this setup pleased with it?
I have a L-Jet system on my 1.8 at the present. With some modification (most expensive of which would be 912 injectors it seems) I am tempted to run this setup. My problem is I plan on keeping and rebuilding my 1.8 and am wondering if modification of the PCV system would be irreversable?
Motor has 9550 Raby cam so I know it is best suited for FI and not carbs. I have to believe the carbs are the cheap way to go though maybe not the best. What will I lose with a carb setup and what size carbs should I be looking at.
Also have a question on what type of exhaust you guys are running and is it getting you more HP? Will have MSDS header and 911 muffler but can I do better?
Thanks for all replies
JKP
