Synchro Slider help, trans help - measurements and wear limits |
Jax914 |
Oct 28 2008, 05:39 PM
Schwienhund Rennenmannshaft Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
OK...
working on my trans. Dissassembled and think I've found the problem, the small shift arm that actuates the internal shift rods controlling the brass sliders - but I digress....that'll be another thread. Trans has been apart before - synchro rings are hardly worn at all and are in very good shape. Wear shown below looks worse that it is... What I'm looking for is wear limits on the synchro sliders. Any maybe someone that might have a decent one laying around. It seems that the pointed teeth on the sliders are worn on one side more than the other. I measured using a depth micro, and searched for the highest tooth on both sides of the slider. One side has a clearance of .019" and the other averages around .023". Is this normal? When new, are the sliders reversable or do they do in one specific way? Also, what is the normal depth between the edge and the point of the tooth. Here are two shots showing my question. One side: (IMG:http://i35.photobucket.com/albums/d182/PunchBug71/914_probs/good_side.jpg) Other side: (IMG:http://i35.photobucket.com/albums/d182/PunchBug71/914_probs/worn_side.jpg) So if anyone has a new one (Dr. Evil - can you help?) would you mind measuring? Then if anyone has a usable slider - let me know what you want for it. Thanks in advance. |
Lo-Fi Version | Time is now: 27th May 2024 - 08:55 AM |
