machining early pedrinis for late rotors, what needs to be done? |
echocanyons |
Oct 28 2008, 09:39 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I may need to have some early pedrinis machined to fit my late rotors.
Is this an advisable thing to do? What exactly needs to be done? Do I need to take them to a machine shop? Hubcentric rotors are only on the front right? thanks! |
davep |
Oct 28 2008, 10:02 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes hubcentric fronts only. Take the rotor to the machinist, and have them turn the rim to fit. The machining has to be very accurate. That is what the factory did.
McMark |
Oct 29 2008, 04:50 PM
IIRC, the back (inboard side) of the wheel needs to have the center hole opened up. The early ones have a taper in the center hole, the late ones have straight 'walls'.
sixnotfour |
Oct 29 2008, 05:42 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
early/late
Eric_Shea |
Oct 29 2008, 05:52 PM
Simply machine the hub centric ring off the rotor. Don't touch the rims. We do this all the time with late rotors that want to convert to 5-lug Fuchs.
G e o r g e |
Oct 29 2008, 06:25 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
sixnotfour |
Oct 29 2008, 09:19 PM
QUOTE Simply machine the hub centric ring off the rotor. Don't touch the rims. We do this all the time with late rotors that want to convert to 5-lug Fuchs. true , but wich is reallly the best way hummmmm?? only 4 lugs . 4 cylinders, hes coming up short already (IMG:style_emoticons/default/av-943.gif) |
echocanyons |
Oct 30 2008, 02:14 AM
Thanks for the advice so far everyone (IMG:style_emoticons/default/smilie_pokal.gif) .
I really like the idea of not machining the wheels, not to mention rotors are so much easier to come by. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:43 PM |
