I may need to have some early pedrinis machined to fit my late rotors.
Is this an advisable thing to do?
What exactly needs to be done?
Do I need to take them to a machine shop?
Hubcentric rotors are only on the front right?
thanks!
davep
Oct 28 2008, 10:02 PM
Yes hubcentric fronts only. Take the rotor to the machinist, and have them turn the rim to fit. The machining has to be very accurate. That is what the factory did.
McMark
Oct 29 2008, 04:50 PM
IIRC, the back (inboard side) of the wheel needs to have the center hole opened up. The early ones have a taper in the center hole, the late ones have straight 'walls'.
sixnotfour
Oct 29 2008, 05:42 PM
early/late
Eric_Shea
Oct 29 2008, 05:52 PM
Simply machine the hub centric ring off the rotor. Don't touch the rims. We do this all the time with late rotors that want to convert to 5-lug Fuchs.
