Whats the procedure... |
914werke |
Feb 9 2004, 07:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
for seperating the wheel hub (?) from the trainling arm?
I pulled the stub axles out and it looks like I have to press them off the inner wheel bearings? Or is there some special trick to unbolting the outer bearing retainer? |
Mueller |
Feb 9 2004, 07:10 PM
Big hammer or press............
make sure the axle is removed from the flange...... yes, the flange is pressed into the bearings...kiss the bearing goodbye once you remove the flange. |
914werke |
Feb 9 2004, 07:18 PM
Mike by flange you mean the thingie that your lugs screw into.
Indeen I have visions of you needles going into these. |
Jeffs9146 |
Feb 9 2004, 07:55 PM
I tapped it out with a pipe and a BFH
(IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) Then the same with the bearing! Jeff |
Bleyseng |
Feb 9 2004, 08:03 PM
Yup use BFH and a big socket and extension to drive the "hub" out of the rear wheel bearings. Some come out pretty easy others take for- ever to drive out.
Geoff (IMG:style_emoticons/default/laugh.gif) |
tat2dphreak |
Feb 9 2004, 08:39 PM
I found a 36mm socket the perfect fit to drive it out... maybe that was just me... good luck... have fun!
Lo-Fi Version | Time is now: 16th May 2024 - 07:50 PM |
