Rear Window Wiring Harness, Have everything else but, Striking out in the garage |
jesiv |
Oct 30 2008, 10:55 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Does anyone have pics of the rear window heating/defrost wiring harness and how the harness is routed?
Thanks for the help. Regards, James |
euro911 |
Nov 2 2008, 12:54 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'd like to install the rear defrost glass as well ... (IMG:style_emoticons/default/popcorn[1].gif)
914Sixer |
Nov 2 2008, 02:07 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It is a straight plug in. The harness is routed through the main tunnel. Rear plug goes into relay board and grounds with other grounds below board. Inside harness plugs into each side of window. Front part of harness goes to dash board. 3 wires go to switch in dash. I do not have the wire colors in front of me.
jesiv |
Nov 2 2008, 03:22 PM
Do anyone have any detailed pics of the harness and how it routes through the firewall? Also, are we saying that there is more than one harness required?
Regards, James |
914werke |
Nov 21 2008, 10:28 AM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
No pics per say but I can provide some 1st hand experiance from my LE
resto. It seems that the harnesess are specific to the build trim level ordered or vintage of the car. They are differentiated by colored tape circling the eng. bay loom sheath (the formed rubber hose that exits the lower FW and routes up through the FW shelf). Ive seen 1 or 2 tape bands but cant be certain of the colors since yrs. heat and grease always take thier toll on the accuracy of ID. This is important to describe since it seems that the accessory loom for the R. window defrost routes INSIDE this sheath. So it seems that when the factory was building the cars they pulled the correct harness for the trim of the car and installed it. Thats not to say you cant install a R. window defrost harness after the fact, just that if your doing a concours resto, reinserting that accessory loom through the sheath might be a bitch (BTDT) (IMG:style_emoticons/default/chair.gif) Its do-able but the sheath condition is important to consider. Again yrs., heat and grime tend to make this rubber ...less than plyable and it can crack/split easily (if it hasent already) runining you otherwise perfect restoration (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 06:42 AM |
