No pics per say but I can provide some 1st hand experiance from my LE
resto.
It seems that the harnesess are specific to the build trim level ordered
or vintage of the car.
They are differentiated by colored tape circling the eng. bay loom sheath
(the formed rubber hose that exits the lower FW and routes up through the
FW shelf). Ive seen 1 or 2 tape bands but cant be certain of the colors since yrs.
heat and grease always take thier toll on the accuracy of ID.
This is important to describe since it seems that the accessory loom for the R.
window defrost routes INSIDE this sheath.
So it seems that when the factory was building the cars they pulled the correct harness for the trim of the car and installed it.
Thats not to say you cant install a R. window defrost harness after the fact,
just that if your doing a concours resto, reinserting that accessory loom through the sheath might be a bitch (BTDT)
Its do-able but the sheath condition is
important to consider. Again yrs., heat and grime tend to make this rubber ...less than plyable and it can crack/split easily (if it hasent already) runining you otherwise
perfect restoration
