rubber, back glass |
oldschool |
Oct 31 2008, 11:52 AM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
what do the back glass rubber look like,mine is missing or something it make a lot of noise when am driving. (IMG:style_emoticons/default/icon_bump.gif)
Lavanaut |
Oct 31 2008, 11:58 AM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Your rear window likely needs to be resealed. Try 'knocking' on it, if it rattles at all, you'll need to redo it. The rubber seal runs along the outside bottom of the window, only, and doesn't serve to hold it in place. The window is affixed with butyl tape, you can pick up a roll cheap at your FLAPS. There's an excellent step-by-step installation guide in the 'classic threads' section of the site written by Eric Shea. I've done this myself twice, not exactly fun, but it's nice when you're done ~ no more rattle!
Good luck. Oh, and this should be posted in the garage forum. (IMG:style_emoticons/default/smile.gif) |
oldschool |
Oct 31 2008, 01:08 PM
Your rear window likely needs to be resealed. Try 'knocking' on it, if it rattles at all, you'll need to redo it. The rubber seal runs along the outside bottom of the window, only, and doesn't serve to hold it in place. The window is affixed with butyl tape, you can pick up a roll cheap at your FLAPS. There's an excellent step-by-step installation guide in the 'classic threads' section of the site written by Eric Shea. I've done this myself twice, not exactly fun, but it's nice when you're done ~ no more rattle! Good luck. Oh, and this should be posted in the garage forum. (IMG:style_emoticons/default/smile.gif) thanks bro. |
oldschool |
Oct 31 2008, 02:33 PM
Your rear window likely needs to be resealed. Try 'knocking' on it, if it rattles at all, you'll need to redo it. The rubber seal runs along the outside bottom of the window, only, and doesn't serve to hold it in place. The window is affixed with butyl tape, you can pick up a roll cheap at your FLAPS. There's an excellent step-by-step installation guide in the 'classic threads' section of the site written by Eric Shea. I've done this myself twice, not exactly fun, but it's nice when you're done ~ no more rattle! Good luck. Oh, and this should be posted in the garage forum. (IMG:style_emoticons/default/smile.gif) sorry about the the post I forgot what area i was in. I can't seem to find the post?help..help... (IMG:style_emoticons/default/blink.gif) |
Lavanaut |
Oct 31 2008, 04:24 PM
My bad ~ click the '914 Info' link up the upper right corner, then go to 'technical articles', you'll find it there.
TC 914-8 |
Nov 1 2008, 07:08 PM
Senior Member Group: Members Posts: 807 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 28th April 2024 - 05:57 AM |
