2.0 heat exchangers, How do I know what is right? |
old9one4 |
Nov 2 2008, 04:11 PM
Newbie Group: Members Posts: 35 Joined: 1-March 07 From: Sunnyvale, CA Member No.: 7,574 Region Association: Northern California |
I have recently purchased a set of 2.0 heat exchangers but I am not sure they are correct. Can anyone tell me how to determine if they are correct for a 2.0 motor. Thanx, Nelson
Nov 2 2008, 04:25 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
All HE's fit all motors.
The 2.0 liter old (up to 75) HE's have a straight profile at the end, they do not turn up like the 1.7/1.8 exhangers. the later 2.0 liter HE's terminate into a single outlet, the older ones terminate in dual outlets. there are basically three types and all must have a specific muffler and muffler bracket that goes with each. All HE's do bolt on and fit all motors... Rich |
dflesburg |
Nov 2 2008, 08:06 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
there is a thread either here or on Pelican that defines and describes all types.
jimkelly |
Nov 2 2008, 08:32 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
Attached thumbnail(s) |
old9one4 |
Nov 2 2008, 10:57 PM
warrenoliver |
Nov 3 2008, 10:11 AM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
pic Slight Hijack: Thanks for the pics Jim. I have a question about the 2.0 heat exchangers/exhaust. I recently changed my exhaust gaskets due to backfire on deceleration caused by a leaking gasket. When I dropped my exhaust/heat exchangers, I noticed that the heat exchangers have an extra bracket welded to the exhaust near the bend of the pipe just below the engine. This bracket is a steel strap about 12" long and 1" wide with two bolts that allow the exhaust to be bolted directly to the bottom of the engine case. (IMG:style_emoticons/default/WTF.gif) When I took off the exhaust nuts, I couldn't drop the exhaust until I detached the bracket. I have already reinstalled everything and I did not take a pic of the bracket. (IMG:style_emoticons/default/chair.gif) My car is a 73, 2.0, FI, that I thought was fairly original. When the Cap'n did a PPI and worked on the car prior to shipping out to me, he never commented on the bracket for the heat exchangers. What the heck is this? It's hard to believe that a PO decided to modify the exhaust like this and then drilled and tapped the bottom of the engine case. Warrenoliver |
Bleyseng |
Nov 3 2008, 10:14 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
sounds like a PO mod to me. Post a pic
Lo-Fi Version | Time is now: 29th May 2024 - 09:44 AM |
