Installing taco plate temp sender., Need some advice. |
KaptKaos |
Nov 6 2008, 11:40 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I have a combo gauge that I plan to install in place of das blinkin licht. It's a stock gauge with gas level on the bottom and the temp on the top. I have found (I believe) the wire under the battery tray that runs up and through the center console. I will test to make sure.
I am planning an oil change with this process. Anyway, I have a few questions before I do this. 1) Are there any tips or tricks to installing the sender and cover? 2) What are the torque settings for those 2 bolts. I know it's a sensitive area. 3) What gauge wire should I run from the sender to the harness in the engine bay? 4) What gauge wire from the harness between the seats to the gauge/dashboard. 5) Any other tips or tricks for those that have done this? Please let me know. TIA |
Lo-Fi Version | Time is now: 18th May 2024 - 01:15 PM |
