Front wheel spacers, Which of the two are better? |
TC 914-8 |
Nov 9 2008, 03:49 PM
Senior Member Group: Members Posts: 809 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I am concidering putting spacers on my front wheels 16X7 to fill out my GT flairs About 45mm of space from my tire to the inside of the flair. I have seen the 21mm used with long studs which would still leave me 23 mm left to fill. How about these 1.25" or 31mm, bolt on with studs? They even come 1.5"(38mm) Any good or bad stories. I have read most of the past threads on spacers but none mention this type. I have also read about scrub radius and all the other stuff. short of me getting 9's for the rear and moving my 8's up front, spacers it will have to be.
PRICING IS FOR ONE PAIR [ 2 ] SPACERS / ADAPTERS AVAILABLE WIDTH: 1.25 Inch CONFIGURATION: 5 x 130 to 5 x 130 STUD SIZE: 14mm x 1.50 CUSTOM CRAFTED FROM 6061 AIRCRAFT GRADE BILLET ALUMINUM. CENTER BORE & HUB IS MACHINED TO YOUR VEHICLES SPECS. INSERTED WITH AUTOMOTIVE GRADE WHEEL STUDS. OPEN END LUG NUTS ARE INCLUDED FOR INSTALLATION Or this one |
messix |
Nov 9 2008, 03:54 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
go with the top hubcentric ones.
TC 914-8 |
Nov 9 2008, 06:19 PM
Thanks for the elaboration Troy,
The 21mm also come in Hub centric, I'm not sure about havinh 65mm or 70mm studs, 944 spacers on Ebay start for $25 a set then get $95 when the bidding is up. How far have you seen spacers go with out hitting the front or rear of the wheel well? |
degreeoff |
Nov 9 2008, 06:22 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
I have the top version (@7/8') and the issue I had was the existing stus stuck out too much and bumped the back of the wheel. I went with longer studs and the a set of 21mm hub centric spacers...work great!
Josh |
JRust |
Nov 9 2008, 07:45 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Hey Tony I have both the 1" & 1 1/4 hubcentric spacers with studs. Decide which you want & I'll sell you one or the other.
Hope your golf went okay the other saturday. Had fun at Rich's that day with some cool WA guys (IMG:style_emoticons/default/biggrin.gif) |
messix |
Nov 9 2008, 08:22 PM
Thanks for the elaboration Troy, The 21mm also come in Hub centric, I'm not sure about havinh 65mm or 70mm studs, 944 spacers on Ebay start for $25 a set then get $95 when the bidding is up. How far have you seen spacers go with out hitting the front or rear of the wheel well? yer welcome |
TC 914-8 |
Nov 9 2008, 08:57 PM
Hey Tony I have both the 1" & 1 1/4 hubcentric spacers with studs. Decide which you want & I'll sell you one or the other. Hope your golf went okay the other saturday. Had fun at Rich's that day with some cool WA guys (IMG:style_emoticons/default/biggrin.gif) Hey Jamie, Golf went good that saturday but sucked this saturday. I guess that's why I'm not on TV. Next time you come this way I'll make a point of meeting up with everyone. What is your experience with either? Should I go with the 1 or 1.25 ? How much do you want for the 1.25" ? how come your not using them. I guess you don't have flairs on your v-8 car. Tony |
JRust |
Nov 9 2008, 10:28 PM
Hey Jamie, Golf went good that saturday but sucked this saturday. I guess that's why I'm not on TV. Next time you come this way I'll make a point of meeting up with everyone. What is your experience with either? Should I go with the 1 or 1.25 ? How much do you want for the 1.25" ? how come your not using them. I guess you don't have flairs on your v-8 car. Tony Well I got them for the 993 wheels I bought. The offset is quite different from the Fuchs. The 1" was perfect for the front. The 1 1/4 was not enough in the rear for the 8" wheels. Neither was my stock fender. That is why I went to the fuchs I have now. If I do gt flares later I will need a good 2" spacer to use the 993 8" rear wheel. I even added 1/4" spacers making it 1 1/2" in the back. Still rubbed on the inside wheels well. I like the look of the wheels but unless I flare they will most likely be sold or stay in the garage. I'd be happy to send you both & u can send back whichever one you don't use. I think I paid $125-150 for the 1 1/4. So lets say $100 shipped. Again I'll send you all 4 just send back the set you don't use. My 993 wheels would look pretty dang good on your car though (IMG:style_emoticons/default/idea.gif) |
PeeGreen 914 |
Nov 10 2008, 12:12 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Tony, I have the ones that slip over your studs as you can change them to whatever you want very easily. I have the 1" spacers on my car and they are a perfect fit with my 8's.
jimsfolly |
Nov 10 2008, 01:05 AM
Newbie Group: Members Posts: 17 Joined: 15-June 08 From: Renton, WA Member No.: 9,174 Region Association: None |
I went with 1.5" front/rear with the 7x16 fuches, with 225/50 tires all around. rear spacing was tight on the glass flares, front had about .5" clearance, and had to trim the front valance a tad.
used the bolt-on hub centric spacers of ebay... one note of caution... the spacer studs were too long for the aluminum lug nuts, I cracked the head on one before I realized I had to shorten them up by about .5"... |
TC 914-8 |
Nov 10 2008, 10:26 PM
I went with 1.5" front/rear with the 7x16 fuches, with 225/50 tires all around. rear spacing was tight on the glass flares, front had about .5" clearance, and had to trim the front valance a tad. used the bolt-on hub centric spacers of ebay... one note of caution... the spacer studs were too long for the aluminum lug nuts, I cracked the head on one before I realized I had to shorten them up by about .5"... Man All you guys are giving me good info, plus good Deals. I think my 7x16's have a 1" off set on them already. So I would be safe with the 1.25's. Jamie did you have any problems with the studs at either end? I have heard of the wheel studs poking thru the spacers and hitting the rims, but not the spacer studs being too long. The rim offset is another animal, i think 1" in front and 1.5 in the rear. I don't know if you can tell from the pict. |
ericread |
Nov 11 2008, 01:32 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Sorry for entering this thread so late in the game, but I thought there was a thread about a year ago that pretty much demonized spacers as being unsafe???
If there new technology to ensure the safety of wheel spacers, or was the older thread wrong? (IMG:style_emoticons/default/idea.gif) Eric Read |
veltror |
Nov 11 2008, 01:49 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Does anybody have a picture of the said spacers without the wheel fitted?
R. |
TC 914-8 |
Nov 12 2008, 12:12 AM
Looks like Jamie has the best option, I picked up a set of 31mm spacers along with a spare .25in set. I'll take some before and after picts. and post them in a few days.
JRust |
Nov 12 2008, 12:19 AM
He TOny I've got them in rig & will get them out tommorow. I'm curious to see how they look. Make sure to take some good close ups of before & after (IMG:style_emoticons/default/biggrin.gif)
TC 914-8 |
Nov 15 2008, 09:44 PM
He TOny I've got them in rig & will get them out tommorow. I'm curious to see how they look. Make sure to take some good close ups of before & after (IMG:style_emoticons/default/biggrin.gif) Got them Friday around 330. I had to get my chores done first before I could put them on. So anyway, got them on by 8PM. They fit like a champ, I had to re-drill my front valance to gain a small clearenceat the bottom of the front wheel well, look close in the before pict. . Here are some pictures. Also I put the 1/4 in spacers on the rear, hey WTF, "you can't be too wide in the rear" , on a car that is.... BTW I would like to shoot you some $ for the 2 day shipping and 1/4' spacers, How much? $25.00 Here is the Before pict. I'll add a few more after this. |
TC 914-8 |
Nov 15 2008, 09:56 PM
Here is a pict with the wheels on in an after pict. notice the front valance is nice and flush. I did take her for a ride today, nice and sunny. I could almost feel a more stabler ride and tighter handling. 2.5" total in the front and 1/2" in the rear added to the foot print, maybe its in my head. Get this, in the rear right I have about 1 finger between the tire and indside of the flair. on the rear left I have almost 2 fingers between the tire and inside flair. Either the rear flairs wern't put on symetrical or the trailing arms are WAY out of alignment????
TC 914-8 |
Nov 15 2008, 09:58 PM
TC 914-8 |
Nov 15 2008, 10:01 PM
JRust |
Nov 15 2008, 10:07 PM
Got them Friday around 330. I had to get my chores done first before I could put them on. So anyway, got them on by 8PM. They fit like a champ, I had to re-drill my front valance to gain a small clearenceat the bottom of the front wheel well, look close in the before pict. . Here are some pictures. Also I put the 1/4 in spacers on the rear, hey WTF, "you can't be too wide in the rear" , on a car that is.... BTW I would like to shoot you some $ for the 2 day shipping and 1/4' spacers, How much? $25.00 Here is the Before pict. I'll add a few more after this. Don't sweat it tony! Glad they worked for you. Always nice to help out a fellow teener. Especially a v8 guy (IMG:style_emoticons/default/slap.gif) We got to stick together (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 PM |
