Front wheel spacers, Which of the two are better? |
TC 914-8 |
Nov 9 2008, 03:49 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I am concidering putting spacers on my front wheels 16X7 to fill out my GT flairs About 45mm of space from my tire to the inside of the flair. I have seen the 21mm used with long studs which would still leave me 23 mm left to fill. How about these 1.25" or 31mm, bolt on with studs? They even come 1.5"(38mm) Any good or bad stories. I have read most of the past threads on spacers but none mention this type. I have also read about scrub radius and all the other stuff. short of me getting 9's for the rear and moving my 8's up front, spacers it will have to be.
PRICING IS FOR ONE PAIR [ 2 ] SPACERS / ADAPTERS AVAILABLE WIDTH: 1.25 Inch CONFIGURATION: 5 x 130 to 5 x 130 STUD SIZE: 14mm x 1.50 CUSTOM CRAFTED FROM 6061 AIRCRAFT GRADE BILLET ALUMINUM. CENTER BORE & HUB IS MACHINED TO YOUR VEHICLES SPECS. INSERTED WITH AUTOMOTIVE GRADE WHEEL STUDS. OPEN END LUG NUTS ARE INCLUDED FOR INSTALLATION Or this one |
Lo-Fi Version | Time is now: 8th June 2024 - 05:49 AM |
