WTB Renshift by JWest |
computers4kids |
Nov 12 2008, 09:03 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm looking for a Renshift kit by JWest. I know I can buy one new but they are $510 bucks...ouch! Anway, looking for the long shot here.
Mark |
MikeSpraggi |
Nov 14 2008, 05:58 AM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
41ghost |
Nov 14 2008, 10:18 AM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
they have gone up in price. but anyway you should just buy a new one , they are great, you should also get the shift linkage also, i love the system , i had put one on my car last year and love it.
c12croft |
Nov 14 2008, 01:43 PM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
Timely topic> I shelled out the $510, had it installed by a Porsche mechanic, and just got back from a test drive.
Fun as hell with the shorter, quicker shifting, but had trouble getting it into 1st gear, and couldn't even find reverse. Before I call I'd like to understand it myself. Anyone familiar with these? |
c12croft |
Nov 14 2008, 02:54 PM
Also; Having trouble with how far up the shifter comes up thru the console, see pict.
c12croft |
Nov 14 2008, 07:19 PM
duh, auto lockout 4 reverse
c12croft |
Nov 14 2008, 07:25 PM
picture of Rennshifter height;
designed that way Attached image(s) |
Tom |
Nov 14 2008, 08:15 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
The Rennshift is great, but the linkage will still need to be correctly adjusted. Also don't forget that the linkage bushings will have an effect on how it shifts. Even new bushings sometimes will not be correct in their fitting. Get a 911SC boot to cover the Rennshift. It will look factory.
Tom |
c12croft |
Nov 16 2008, 02:11 PM
The Rennshift is great, but the linkage will still need to be correctly adjusted. Also don't forget that the linkage bushings will have an effect on how it shifts. Even new bushings sometimes will not be correct in their fitting. Get a 911SC boot to cover the Rennshift. It will look factory. Tom Tom, Thanks for clueing me in. Is the linkage difficult to adjust? |
biosurfer1 |
Nov 20 2008, 10:59 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
the first time? can be difficult...gets easier after that
Cevan |
Nov 21 2008, 09:19 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
The Rennshift is great, but the linkage will still need to be correctly adjusted. Also don't forget that the linkage bushings will have an effect on how it shifts. Even new bushings sometimes will not be correct in their fitting. Get a 911SC boot to cover the Rennshift. It will look factory. Tom Tom, Thanks for clueing me in. Is the linkage difficult to adjust? Rich T gave me a good suggestion. Just take a pair of vice grips and a ratchet (13 mm I think), and get in the car and drive it. With the rear access panel exposed, you can make small adjustments and test it out. I got mine perfect in about 10 minutes. |
c12croft |
Nov 21 2008, 03:08 PM
The Rennshift is great, but the linkage will still need to be correctly adjusted. Also don't forget that the linkage bushings will have an effect on how it shifts. Even new bushings sometimes will not be correct in their fitting. Get a 911SC boot to cover the Rennshift. It will look factory. Tom Tom, Thanks for clueing me in. Is the linkage difficult to adjust? Rich T gave me a good suggestion. Just take a pair of vice grips and a ratchet (13 mm I think), and get in the car and drive it. With the rear access panel exposed, you can make small adjustments and test it out. I got mine perfect in about 10 minutes. Thank you, Adjusting it while it's driven? Can you pont out the rear access panel? |
PeeGreen 914 |
Nov 21 2008, 08:24 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Okay... this is the best advice for getting your Rennshift in perfect placement. Since the Rennshift plains in second -third climb under you car and undo the boot so you can manualy put your car in gear. Put you car in third. Go to your shift lever. Make sure your throw out bolts are loose and out of the way until you get this adjusted correctly. Now get the rod on the bolt so you can get a wrench to it. Remember you are in third so it should be where you would have the shifter while in third. Tighten it and see how it feels. Should be perfect. Now you just need to adjust the throw out bolts.
Lo-Fi Version | Time is now: 20th May 2024 - 06:01 AM |
