It's just pointless |
F4i |
Feb 11 2004, 08:06 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
A great many of you have installed pointless ignition. I am having a problem with a unit called Acu-fire that is supposed to just be a compu-fire sold by empi. I put everything together as per the instructions and the magnetic rotor rubs on the unit. I did use the spacer below the rotor and it still rubs. The instructions call for a .060" gap. Has anyone had this problem? Any ideas? Thanks.
steve@ottosvenice.com |
Feb 11 2004, 08:18 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
How much end play in the dizzy? Steve
F4i |
Feb 11 2004, 08:35 PM
The top shaft has about 0.030" the bottom maybe .001". I am not going to find .060" here. BTW what should the play be?
914ghost |
Feb 11 2004, 11:55 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
I just installed exactly the same thing in my 050 distributor, had no problems but the magnetic rotor was a little bit loose.
Its possible that there are different dimensions in the vacum dist.? I cant think of why it would rub W/ the spacer. ...? I'll look at mine though. Bob O |
Air_Cooled_Nut |
Feb 11 2004, 11:57 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
It's possible you got the wrong unit. I know with Pertronix there are different units depending on if the dizzy is FI or mechanical.
F4i |
Feb 12 2004, 12:13 AM
The kit says it's universal and on the instructions it says to use the spacer below the rotor(magnet) for dist. with vac. advance. Does anyone know it I have too much play in my dist. ?
914 ghost thanks for having a look (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:53 PM |
