F4i
Feb 11 2004, 08:06 PM
A great many of you have installed pointless ignition. I am having a problem with a unit called Acu-fire that is supposed to just be a compu-fire sold by empi. I put everything together as per the instructions and the magnetic rotor rubs on the unit. I did use the spacer below the rotor and it still rubs. The instructions call for a .060" gap. Has anyone had this problem? Any ideas? Thanks.
steve@ottosvenice.com
Feb 11 2004, 08:18 PM
How much end play in the dizzy? Steve
F4i
Feb 11 2004, 08:35 PM
The top shaft has about 0.030" the bottom maybe .001". I am not going to find .060" here. BTW what should the play be?
914ghost
Feb 11 2004, 11:55 PM
I just installed exactly the same thing in my 050 distributor, had no problems but the magnetic rotor was a little bit loose.
Its possible that there are different dimensions in the vacum dist.?
I cant think of why it would rub W/ the spacer. ...?
I'll look at mine though.
Bob O
Air_Cooled_Nut
Feb 11 2004, 11:57 PM
It's possible you got the wrong unit. I know with Pertronix there are different units depending on if the dizzy is FI or mechanical.
F4i
Feb 12 2004, 12:13 AM
