How do you clean your Transmission/Engine |
RiqueMar |
Nov 13 2008, 12:59 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
I have multipe Trans. and Engines that have years of caked dust/dirt/mud/etc on them.
What is the best way to getting them to look new? Power washing? Parts cleaner? I know this is such a newb question, but hey! I'm a Newb! (IMG:style_emoticons/default/unsure.gif) |
ericread |
Nov 13 2008, 02:34 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Sorry for the non-serious response, but I love this image from last year...
Eric Read (IMG:style_emoticons/default/lol3.gif) |
RiqueMar |
Nov 13 2008, 03:54 PM
Hey, it's the first response I've gotten, I just don't know what to do.
Rand |
Nov 13 2008, 03:57 PM
Steam cleaners rock. But not everyone has access to them.
You could take them down to a carwash with the pressure wands, soak everything good with brake cleaner (or see if someone chimes in with a better chemical), let it work a bit, then power wash it off. |
jd74914 |
Nov 13 2008, 04:10 PM
I've always used a big shop sink, a ton of degreaser, maybe some brake cleaner, rags, and a wire brush. You can clean off pretty much everything that way, it just takes time.
Though if you want to clean assembled stuff a powerwash isn't too bad an idea. Just make sure you don't do it over any grass. |
Johny Blackstain |
Nov 13 2008, 04:15 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
If I remember correctly, Dr. Evil recommended Easy Off & a power washer for the tranny.
RiqueMar |
Nov 13 2008, 04:21 PM
Right on, any other "hot tips"?
Spoke |
Nov 13 2008, 04:27 PM
I used a small screwdriver to scrape off the caked mud on my tranny. Looks good enough.
Cap'n Krusty |
Nov 13 2008, 04:45 PM
Whatever you use, be careful! I wouldn't steam a tranny unless it was coming apart right away. That Castrol purple cleaner can EASILY put you in the hospital, so use it in a WELL ventilated place with a good breeze blowing. Easy Off can damage the magnesium tranny case and other bits, so be careful there, too. Oh, staem cleaning can permanently discolor aluminum engine cases (OK, anything made of aluminum .............. )
The Cap'n |
Rav914 |
Nov 13 2008, 04:54 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Simple Green and a powerwasher connected to the hot water tap.
Ericv1 |
Nov 13 2008, 04:55 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
Drench the tranny with degreaser. Use a wire brush to get the caked on dirt off. Rinse the degreaser off with water. Don't do it over grass that you want to live. |
Ferg |
Nov 13 2008, 05:01 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Oil Eater, they sell the stuff at Costco, and I like it far better than the simple green and purple power stuff. Works better IMO and less nasty.
http://www.oileater.com/ Ferg (IMG:style_emoticons/default/aktion035.gif) |
kconway |
Nov 13 2008, 05:05 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Can't you just take it to a machine shop and have them stick it in there parts wash tank? That is if it's disassembled.
brant |
Nov 13 2008, 05:27 PM
I don't think I'd powerwash any motor or tranny that I wasn't going to disassemble.
too much chance for water to get inside I've power washed cases and things I had apart in the past. but for a tranny or motor that I'm not taking apart I usually spread out a big piece of cardboard and use: - naphtha (solvent) I put some in a coffee can - a variety of brushes (tooth brushes, paint brushes, brass bristled brushes) - a spatula - an old screw driver this way I control how much gets onto the tranny nothing gets inside I roll the tranny over to get the sides and bottom it takes time but comes out pretty decent I wouldn't suggest getting any liquids inside other than grease brant |
Dr Evil |
Nov 13 2008, 05:32 PM
Easy Off oven cleaner and a pressure washer are what I have used with low effort and good success. I did an experiment with a tranny case and put Easy Off on it for over a month, kept soaking it, when I finally washed it off it was not damaged. Easy Off is not strong enough to eat your case, that is an urban myth.
Cap'n Krusty |
Nov 13 2008, 07:04 PM
Easy Off oven cleaner and a pressure washer are what I have used with low effort and good success. I did an experiment with a tranny case and put Easy Off on it for over a month, kept soaking it, when I finally washed it off it was not damaged. Easy Off is not strong enough to eat your case, that is an urban myth. I yield to your experience, anecdotal though it may be .............. The Cap'n |
Dr Evil |
Nov 13 2008, 07:14 PM
Anecdotal?! (IMG:style_emoticons/default/bootyshake.gif)
Def: based on or consisting of reports or observations of usually unscientific observers My study was scientific. It was only lacking in that I didnt repeat it over and over again. Nor will I as it is pointless. I set the parameters to be obscene in that I soaked the palate for 1 mo. Before one does a study they first see if there is a reaction to study, there was no significant one here. When used for a normal amount of time required for cleaning (less than a month), Easy Off has thus far proven to be non damaging. (IMG:style_emoticons/default/dry.gif) |
davep |
Nov 13 2008, 07:19 PM
For the tranny I remove the vent, and plug with a wheel bolt.
Then I take to the local transmission shop for cleaning. Upon return I replace the input and output shaft seals. |
Al Meredith |
Nov 13 2008, 07:24 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I used to take my engine case to AAMCO and they put it their washer. $20.
Richard Casto |
Nov 13 2008, 07:53 PM
For the magnesium parts, Mineral Spirits, nylon scrub brush and elbow grease. Simple Green also works well. Dr. Evil may have had good results with the Easy Off, but I personally would be concerned about potential damage to machined surfaces.
Your next question should be "How should I protect the magnesium case once it is clean". My suggestion is CRC brand "Heavy Duty Corrosion Inhibitor". It is a Tectyl like spray on wax coating. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 AM |
