My Megasquirt Project |
atmadsen914 |
Nov 17 2008, 10:00 PM
Am I sure I like old cars? Group: Members Posts: 45 Joined: 7-September 07 From: Carlinville IL Member No.: 8,087 Region Association: Upper MidWest |
I just finished up my megasquirt project.
I swapped my 1.7L D-Jet. The D-Jet is a pretty good system but I built a 2.0L and I had a hard time getting the parts for the 2.0L D-Jet system. The parts are out there just expensive. So I guess I based my decision to switch on cost. I bought the kit from DIYautotune they did great. They shipped incredibly fast. I did all the assembly in a day. It took me a while to wire up the system. I used the stock temperature sensors. 2.0L injectors (I would probably not do that again the 1.7 injectors probably seem a better choice), LC1 wideband O2, and a TPS from a 98 Hyundai Accent. I used the in series resistors and did not use PWM. The rest of the system is pretty much stock (ignition, etc). It took me a bit to get it all wired up but it really was not that hard. I would say the engine rebuild was harder than the MS setup. I am sure I will be tuning for weeks as the tweaks that can be done seem endless. But pretty much after 30 min of tuning I had a VE table that worked pretty well. Bottom line I love the system! |
GeorgeRud |
Nov 17 2008, 10:04 PM
It seems that the Megasquirt system is a very viable and affordable system for many cars. I've been considering one for my 914-6 conversion instead of the old Weber carbs. At least you won't smell like a gas station when you park the car in your garage!
toon1 |
Nov 18 2008, 12:30 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Good job!!
I enjoyed the process of putting the system together and getting the car running.I am running MS&SE with a ford coil, inj's. and trigger wheel. It's nice to have the adjustability of a PEFI. Tuning is addicting, good luck. |
RJMII |
Nov 18 2008, 01:33 AM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Pictures would be good. =o)
so would a story on the initial fire up process. (I'm working on my MS-II install still. going with Ford EDIS to control spark) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 PM |
